Identification gelcoat/balsa damage
Discussion in 'Fiberglass and Composite Boat Building' started by Nachtvlinder, Mar 2, 2021.
  1. Nachtvlinder
    Nachtvlinder Junior Member
    I ran across below artifacts on a boat from 1977 located in The Netherlands.
    Who recognizes this type of damage? This is the original, non-painted gelcoat. How could this be repaired to get a durable uniform gelcoat appearance? If not repaired, will this get worse over time or become structural affecting the strength or stiffness of this boat?
    According to the builder:
    The deck is cast with 7 layers of 450 g fibreglass matting sandwiched with 10 mm balsa core. Hull and deck are moulded together to form a single, strong, watertight unit. Fore after and locker hatches are vacuum moulded in double fibreglass.
    thx, Maarten
    Likes: 1,455, Points: 123, Legacy Rep: 2031
    First you should inspect for delamination and water intrusion. A plastic hammer will let you know if there is delamination. A moisture meter will find water under the fiberglass. The minor blistering is probably cosmetic. You can refinish in either gelcoat or a good quality paint. In any case, hiring a marine surveyor is probably a good investment.
  3. wet feet
    Likes: 266, Points: 83, Legacy Rep: 124
    wet feet Senior Member
    Unless you bought the boat-walk away.If you have already handed over money,prepare yourself for a fairly big expense on top of the purchase price.It takes many hours to restore the appearance of even faded and dull gel.If,as is possible, the blisters are a sign of osmosis it gets worse.You need to determine if this is likely.A survey would be one way.
  1. T Brown
  2. Klink Sanford
  3. finnatic
  4. aaronhl
  5. Laurance
  6. TBC Marine
  7. mrdebian
  8. aaronhl
  9. aaronhl
  10. JackyJ243
