I need lines plan of a bulk carrier
Discussion in 'Boat Design' started by greg77, Jan 20, 2022.
  1. greg77
    greg77 Junior Member
    Hi, i am a student at university of Athens. The assigned project is a bulk carrier with the following particulars: LBP=227 m , D=20.5 m , B=33.4 m , Cb=0.873 and DWT=85900 t.
    We are supposed to create the lines plan in Aveva, but i haven't any original to work with. Can anyone help me send the lines plan of a similar ship to continue the project?
    Thanks for your time!
  2. jehardiman
    Likes: 1,482, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Check out Ship Design and Construction (SD&C) by SNAME. Lots to copy from in there. Read it and you may learn why bulker lines are the way they are.
  3. bajansailor
    Likes: 1,840, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    Would it be possible to start off in the traditional fashion working by hand drawing with a sectional area curve and a midship section and then later transferring it to your CAD program?
    I had to google Aveva - it does look very impressive.
    https://www.aveva.com/content/dam/a...esignMarine_06-21.pdf.coredownload.inline.pdf
  4. greg77
    It is a possible thing to do, if you can direct me with the process. I only have the midship plan and stability booklet of my parent ship. How do i proceed to mine particulars?
  5. TANSL
    To start with "a sectional area curve" (I guess that's the curve of the frame areas along the length of the ship) the first thing you'll need is to know the shapes of the frames.
    Perhaps it is preferable to start, as many people do, by copying the shapes of a similar (not the same) ship and applying a change of scale to it (an affine transformation would be preferable)
  6. greg77
    Where can I find a similar shape though? You mean the body plan?
  7. TANSL
    Yes, the body lines plan.
    I may have something similar, need to check my files. Send me a pm with your e.mail.
  8. greg77
    I am a new member and can't pm at the moment. How can we come in touch ?
  9. TANSL
  10. greg77
  11. TANSL
    I have sent information to your personal email. I hope you find it useful. For any questions you need, I am at your disposal.
    Will Gilmore likes this.
  12. Kayakmarathon
    Likes: 49, Points: 28, Legacy Rep: 10
    Kayakmarathon Senior Member
    It is better to start from scratch since the assignment is as much about learning the tool as it is the shape and structure of the ship. Your grade may not reflect the amount of learning you accomplished, but you will gain valuable insight. College is the place to make basic mistakes, not at your first job.
    DogCavalry and DCockey like this.
    1. Navindu Karuanrathne
    2. Puteri
    3. johncarlo
    4. heavyweather
    5. Yara Elboraie
    6. Alexandre.fry
    7. the brain
    8. Tommy Earl
    9. Morileck
    10. Phil Magnuson
