I need help scantling boat aluminum bureau veritas
Discussion in 'Boat Design' started by moha, Mar 22, 2022.
  1. moha
    moha New Member
    any one know how calcule thiknisse in bv2021 nr 600 hlep
  2. AlanX
    Likes: 21, Points: 28
    AlanX Senior Member
  3. Ad Hoc
    Likes: 1,971, Points: 113, Legacy Rep: 2488
    Ch.4 Sec.3
    2.2.2 a)
  4. moha
    moha New Member
    thanks for your info .
    i have other problème i calcul module section (Z ) and section âme (Asa) of each primary and secondary element . how i get stiffener(hw tf ...)
  5. moha
    moha New Member
    if you have exmple of scantling aluminium workboat or any boat - 20m with BV can ypu share with me plz
  6. AlanX
    AlanX Senior Member
    Moha,
    If you are actually planning to build a boat yourself for yourself then you don't need that Standard.
    I would recommend: "Designing Power & Sail" by ARTHUR EDMUNDS
    It has worked examples of the basic design calculations you require.
    I did pick up one formula error however. I cannot tell you where as I am one a road-trip.
    Best of luck, AlanX
  7. aldy syahri
    Likes: 1, Points: 1
    aldy syahri Junior Member
    Hi Moha, you should read it step by step and read carefully. Basic naval architecture or equivalent is helping you to do that. Try to read ISO small craft for simple learning then you can go on with others rule.
    But if you want to jump on the thickness go with ad-hoc pict then then you will go turning every pages to find out the coefficient you want from equation to another equation. Sometimes it makes you dizzy
