Hi Vronsky, from my personal experience with hydraulic steering (manual hydraulic steering (simpler one), not power steering), I think this is the order in which the simplest steering system should/could be designed:
1. Find the hydraulic cylinder that fits your required geometry (of course, something reliable and hopefully for marine use). This is the key point (type of mounting, stroke of the cylinder, etc., e.g. you already know that you need bull-horn type as you have stated). Selected cylinder will have some defined cylinder capacity. My wild guess is that when you find it, it will be more than powerfull enough for your need, no matter of engine power.
2. Find the suitable helm pump and steering wheel. Mind that the power required for steering is defined by the ratio of the helm pump capacity and the cylinder capacity. If you want more steering power, you need bigger capacity of helm pump, but this leads to more steering wheel rotations from end to end position and vice versa, if you want less rotations of steering wheel from end to end position, you need smaller capacity of the helm pump, but it will be harder to rotate the wheel. In addition, selection of the steering wheel diameter can also help to fight the force if required (think of a diameter as a lever).
3. Deal with hoses, fittings, mounting elements, etc. (sounds simple, but sometimes it could return you back to rethink step 1)
To skip math and more detailed explanation here about each step, I recommend reading the following links, which will give you enough knowledge to understand the whole system better and to calculate your wheel rotations when you have the capacity numbers of chosen cylinder, helm pump and known maximum angle of motor from end to end position. You could probably skip some of materials in links if you know what you need.
Marine Hydraulic Steering Systems https://www.sbmar.com/articles/marine-hydraulic-steering-systems/
Understanding Basic Marine Steering Ram Geometry https://www.sbmar.com/articles/understanding-basic-marine-steering-ram-geometry/
I think for deeper technical understanding, the previous link could be of help, but if not interested in that skip it and use only Seastar/Dometic documents and support, as stated by DogCalvary.
