Hello there,
This is my first post and I’m sure it won’t be my last!
Beginning this week I have begun the almighty task (well what is for me) of re-coring the deck of my Trident Warrior 40, due to years of water ingress/core rot from a poorly maintained teak deck by the previous owner.
Ive owned her for the best part of two years and in this time have also come to the conclusions that the hull to deck joint/toe rail area (toe rails are aluminium) on both port and starboard side along most of her length is also leaking. Upon removal of the toe rail I’ve noticed that they are quite badly corroded/pitted and the sealant used to bed them down was dry and deteriorating in places.
I understand that having the hull deck joint bolted together is what is giving the joint it’s strength.
Instead of having to buy new toerails (which aren’t exactly the cheapest) and possibility of leaks again in the future. Can I fiberglass the hull/deck joint together eliminating the toerail completely and keep structural integrity of the hull/deck joint without any problems, I’ve attached a photo of the type of hull deck joint. My plan would be to use 6” wide strips to tab the inside and when it comes to laying fiberglass over the new core tabbing the deck to the side of the hull ?
Thank you
Thank you
