ram68ocean
Junior Member
- Joined
- Mar 13, 2013
- Messages
- 50
- Reaction score
- Location
- Europe
Thanks for pointing this out. Still the beam could be wider and the length shorter to bring down the L/B ratio. The idea behind making it slender is to reduce fuel consumption.This is a rather skinny vessel, with a L/B of approx 4.4 - the 'average' type of power boat usually has an L/B ratio around 3.
I know. I was having issues with the trim at both conditions. Perhaps a water ballast tank(s) is needed.So does this mean that the difference between the lightship and fully loaded conditions is approx 8 tonnes?
If so, then that is a heck of a lot of difference!
Interesting point. I wasn't aware of this direct relationship between wave height and beam.Re the 'offshore heavy seas', bear in mind that there is a relationship between vessel beam and wave height re waves capsizing a boat - I think it is something like a capsize scenario could happen if the wave height is equal to the beam, and the vessel is caught beam on to the seas.
Which would suggest that your autonomous vessel could capsize in 11' high waves out in the ocean.
Yes a catamaran was considered but disregarded due to higher roll period.
