Hull series data
Discussion in 'Boat Design' started by anuprdk, May 13, 2018.
  1. anuprdk
    anuprdk Junior Member
    Hi
    Does any one know where I can get section data of planing hull series 62?
    thanks
    anup
  2. TANSL
    Likes: 933, Points: 123, Legacy Rep: 300
  3. anuprdk
    Sir,
    Thank you for the data. But what does Bp/ Bpa mean? And what about sectional areas? If I use a scale and measure the body plan, for fairing it i will still need station areas.
  4. TANSL
    Bp = beam or breadth over chines, excluding external spray strips.
    Bpa = mean breadth over chines, Ap/Lp
    Ap = projected planing bottom area, excluding area of external spray strips
    Lp = projected chine length
    What I would do is, using these pictures, draw the body lines plan with any CAD/drawing program and calculate with it all the values you need.
  5. anuprdk
    Bp/ Bpa is around 80% and 120% at stations 0 and 60? what does this actually mean? I am kind of confused as to what Bp and Bpa actually stand for.
  6. TANSL
    Sorry if I'm a bit direct but :
    What exactly do you need?
    Do you know what a chine is?
    Do you know what is projected planing bottom area?
    Do you know what is the projected chine length?
  7. anuprdk
    Sir
    I am knew to planing hull but I do know what a chine is. I just dont understand the concept of projecting the planing bottom area, chine. What purpose does it serve? And where does Bp, Bpa fit?
  8. TANSL
    I thought that, when you asked about "planing hull series 62" you already knew what a planing hull is and you would have a slight idea of how its shapes are and how its dimensions are measured. If not, I recommend that you start studying from the beginning.
  9. anuprdk
    Yes Sir. Any suggestions on what books i should refer?
  10. TANSL
    There are many books that you should read but it depends, fundamentally, of what your current knowledge is. An interesting, easy-to-read book is "The Nature of Boats" by Dave Gerr.
  11. DCockey
    Likes: 677, Points: 113, Legacy Rep: 1485
    DCockey Participant
  12. TANSL
    No, thats not corrct.
  13. Angélique
    TANSL, please point out what you think to be not correct, and please post what you think the correct info there should be.
  14. DCockey
    DCockey Participant
    From Performance By Design, Donald L Blount, p 311:
    "Ap projected area of hull bottom bounded by chines and transom"​
    Performance By Design also has a discussion of Ap 0n pp 57-59. Donald Blount was one of the two authors of Resistance Tests of a Systematic Series of Planing Hull Forms which was the original published report on Series 62. It is the source of the Series 62 lines which TANSL provided above.
    (Name of paper corrected)
  15. DCockey
    DCockey Participant
    Another definition of Ap which is equivalent to Blount's quoted above and the one I provided above:
    Ap Projected area on the free surface from the hull, below and including the chine.
    Source: Resistance Tests of a Systematic Series of U.S. Coast Guard Planing Hulls NSWCCD-50-TR-2005/063 December 2005
