How To Add A Track To Carbon Fiber Mast?
Discussion in 'Materials' started by zstine, Apr 8, 2017.
  1. zstine
    Likes: 18, Points: 18, Legacy Rep: 10
    zstine Senior Member
    I've always dealt with Aluminum masts. I have a friend with a carbon mast who wants to add a track for a spinnaker pole. What is the technique to add fittings to a carbon mast? Can you just drill and tap like an aluminum mast? does he need to somehow reinforce the area? if so, what is the preferred method?
    Thanks!!
    zach
    Likes: 2,321, Points: 123, Legacy Rep: 2031
    It depends on the mast. There are no generic answers. Can you be more specific as to the dimensions and construction of the mast and the intended location of the track?
  3. PAR
    Stainless "nutserts" of an appropriate size would be my recommendation, assuming the wall thickness is fairly hefty.
  4. brian eiland
    Likes: 263, Points: 93, Legacy Rep: 1903
    brian eiland Senior Member
    I wonder if gluing it on with something like 'Plexas adhesive' might work?
    http://www.itwplexus.com/industries/marine.cfm
    Perhaps the addition of just a few mechanical fasteners as well, but I would try to keep from 'puncturing' the carbon tube as much as possible. Then be careful of electrolysis possibilities between any metals involved.
  5. rwatson
    rwatson Senior Member
  6. revintage
    Likes: 107, Points: 43, Legacy Rep: 10
    revintage Senior Member
    Plexus MA422
