Note: This feature may not be available in some browsers.
my questien is, how do i do the hull, is it OK to do 6 layers of 450g fiberglas?
ore shud it be 4 layers and divysel, then 3 layers abow ?
/QUOTE]
I do´nt know the original laminate, maybe someone else will chime in!? Do just a solid layup, no core! if you do as the others have done (shown in the pictures you do´nt have wide sections with unsupported skin, so you do´nt need additional stiffness (and that would be the only advantage of foem core). But foam is always in risk of water intrusion, that is just another risk you do not need. 6 layers should do the job very well in my opinion. It is fabric, no mat ja? In the 4th picture that looks like mat. Use fabric, mat is just weight but has not much strength.
Do not enclose the compartment forever and eternity! Make a inspection hatch / hole.
Regards
Richard
I am not sure what you say.
correct!i think you want me to use this:
yes but that is mainly the resin the mat does not add much!last year i build a rof extenton, an i only use the thinf you cald Mat, i feedl werry strong.
You can, but I do not recommend. Use one layer of mat outside (so, the fabric pattern will not "print through") than fabric/mat, fabric/mat, fabric, thats it. The mat between the fabric layers helps to avoid dry spots and air entrapped, but structural has not much effect.can i go for 2 layers of mat 2 layers of fabric and last 2 laers of mat agen ?
Thats right, make some soft corners, tabbed with cloth.and use som extra layers of fabric in all courners.
Good luck, lets have a picture when finished.
Richard
Gentlemen, I hope you don't mind me joining in your conversation as I have a thought or two.of course, it's not so easy to en what inside my head.
I will only extend swimplatform, so I do not move the rudders or something (the boat has straight axles)
Swimplatform is extended 4 feet.
My boet is stern hawy, and neds 4 trimlabel full down, so i am doing an hul extention below the swimplatform, is extention is 3 feet.
i am adding 2 trimlabels to it. its the only thing how is going to be monted on it.
The boat has propeler tounels and rouder is monted on the stern, so i need to do tounels on the new extention to. the rouders is outside the tounels when fully tilted, so i can not do rounded tounels on the extention.
her i som pictures.
one of the pictures is from an boat how has somting like tis don (foundit on internet)
