Note: This feature may not be available in some browsers.
When we (Roger Macgregor and I, Mike Inmon) were testing the righting moment or self righting of the 26M ( you can see the movie on the macgregorsailboats.com) we had a scale and blocks, etc to measure the force needed to hold the Mac on its side; he said "wonder how much thrust the 50hp Merc bigfoot has"? We hooked it up to the dock and to a scale
using one block so we would still be on scale. Result, exactly 750 lbs on the dial at wide-open. 25lbs per hp by measure includes all the prop loses and one ball bearing block thrown in. Cool huh! All that math was just about the same as the totally unrelated testing by totally uninvolved folks. I could have done that math, yes I could have!
Very cooland! we now know about what it takes to plane a 26' sailboat
in real numbers. Great! Thanks Mike.
I wonder if you scaled down tug /AHTS vessels hp and bollard pull you get a meaniful number at the bottom end of the scale?
re the low numbers, I;ll bet if you give me a ski handle tied to a say a 15 hp I could hold it on the dock...
Think about say an outboard of say 100hp, put both feet in a single ski and no way will it pull you up so the skier is holding all that force less the fact it will be pulling you through the water at about 4-5 kts...what did I just prove?
