How can I determine the position of waterline during the inclining process of a ship
Discussion in 'Stability' started by xichyu, Nov 28, 2016.
  1. xichyu
    xichyu Junior Member
    Many ships capsized because of various reasons. I want to know the variation of ship stability in the process of heel angle change.
    My thinking is that the waterline must be determined firstly,then the displacement and the centre of buoyancy. The center of mass and weight are constant. So the ship stability can be solved.
    I want to calculate the ship stability by MATLAB because of too much data. So I must constantly determining the intersections of ship sections and watersurface.
    How to obtain the waterline?
    In the book of ship's hydrostatical theory, the intersections of ship sections and watersurface are given.
    My teacher just taught us the calculation method of big-angle tilted ship stability,but he did not tell us the method of determining the position of waterline during the inclining process of a ship.
  2. Heimfried
    Likes: 153, Points: 43, Legacy Rep: 37
    Heimfried Senior Member
    Stability is defined as the ability of a ship to resist a heeling (or trimming) moment respectively regain its upright floating position, if the heeling moment disappears.
    Stability is not a physical quantity.
    So if you want to calculate stability, which quantity is representing the stability in your thinking?
  3. xichyu
    Righting moment=GZ*Displacement
    So, I want to calculate GZ(righting arm).
  4. Heimfried
    I Think, you will know, that there is no analytical solution, but an iteration is needed.
    The way I use, is to subdivide the hull along its cartesian coordinates x, y into small upright "sticks" of a rectangular horizontal section.
    There must be an array describing the shape of the hull. You know the position (x, y) of the center of each stick and the z coordinate tells you the draft of the stick in the upright position of the vessel. Sum up the draft of all the sticks and multiply by the area of the stick section. So you have the displacement volume (DISPV).
    When you set the heel angle, you are able to calculate the degree of immersion of every stick by using tangens function. Recalculate the DISPV (DISPV temporary) and you will find, it is not eaqual to the initial DISPV.
    Now starts the iteration: you have to decrease or increase the draft of the vessel, until its DISPV temp is nearly eaqual its DISPV ini.
    Simple pics of the hull "sticks" to illustrate the thought (I hope, you will recognise the "boat"):
    https://www.boote-forum.de/showthread.php?p=3758453&#post3758453
    https://www.boote-forum.de/showthread.php?p=3758478&#post3758478
  5. xichyu
    Thanks for response!
    I thought long and hard about the problem.
    I could not find the mathmatical method for the iteration:
    So,I wish you would introduce me some mathematical methods or related literatures or cases.
  6. Heimfried
    I think it is a good idea to use MATLAB, but my knowledge on that software is less than poor. And unfortunately practical application of matrices I don't know better. Also I know no literature on this topic to recomment it.
    I did solve this floating body problems with arrays.
  7. Heimfried
    To give you an idea of the iteration I meant, an exemplary snippet of code written in a symbolic language ("//" indicates a comment):
    Code:
    dispvini = 123456  // set the initial displacement volume DISPV (deriving from weight of Boat, crew, gear ...)
    dispvtmp = 0 // initialise the variable to contend the temporary DISP
    epsilon = 15 // an appropriate chosen small amount of deviation in DISP you allowe
    af = 0.002 // an appropriate choosen factor to scale the step of iteration (has to be evaluated)
    DO disp // calls a procedure which determines the temporary DISPV depending on draft (T), heel (phi) and trim (theta); procedure sets dispvtmp to the new value
    WHILE (ABS(dispvini - dispvtmp) > epsilon)          // while the absolute value of the difference between initial (given) DISPV and temporary (actual) DISPV greater than epsilon
       IF (dispvini > dispvtmp) THEN                     // if ini DISP greater than tmp DISP
          T = T + (ABS(dispvini - dispvtmp) * af)   // small increase of T
       ELSE                                                   // if tmp DISP greater than ini DISP
          T = T - (ABS(dispvini - dispvtmp) * af)  // small decrease of T
       ENDIF
       DO disp // sets dispvtmp to the newer value corresponding to the altered T
    ENDWHILE
  8. Mermaid Co
    Likes: 4, Points: 8, Legacy Rep: 10
    Mermaid Co Junior Member
    Waterline Determination
    Waterline is the product of hull lines, lightship weight and deadweight so first step is define these parameters correctly.
  9. gonzo
    The density and placement of the cargo also have a huge influence on the stability.
  10. xichyu
    Thanks for your help!
