house Paint for small wooden boat
Discussion in 'Materials' started by minno, Apr 24, 2017.
  1. minno
    minno Junior Member
    Hi All
    After a lot of research I'm thoroughly confused.
    from everything I've read it sounds like an oil based alkyd enamel over an oil based alkyd primer is the way to go.
    unfortunately oil based gloss enamels are hard to come by in Canada although oil based alkyd sealer/primers are available.
    so would a water based alkyd enamel over the oil based alkyd primer sealer work well?
    minno
  2. Mr Efficiency
    Is it unpainted, or has been previously painted ?
  3. minno
    minno Junior Member
    it hasn't been painted yet.
  4. Mr Efficiency
    Being unpainted gives you more options. Unless the boat is a work of art, I'd probably opt for a one-pack polyurethane finish, cheap enough and gives a hard-wearing, smooth glossy finish. May be able to apply that direct to the timber, though I'd probably thin with some penetrol to get better adhesion for the initial coat. I'd avoid water-thinned "enamels" as they leave a lot of brush marks.
  5. Milehog
    Likes: 183, Points: 43, Legacy Rep: 215
    Milehog Clever Quip
    Will the boat live out in the weather or be covered most of the time.
  6. minno
    minno Junior Member
  7. Mr Efficiency
    Yeah, clear polyurethane is used for floors, but you presumably want a pigmented version, they are usually found in marine paint product ranges, but there are coloured polyurethane paving paints, for example.
  8. Milehog
    Milehog Clever Quip
    Porch paint is tough but a bit work boat like.
  9. gonzo
  10. minno
    minno Junior Member
    Thanks Guys :)
    I've been looking at the Armor Coat from Canadian Tire Gonzo posted, I'll go with that one, it's alkyd porch paint fortified with polyurethane, that covers all recommendations:)
    I'm putting it on over oil based alkyd primer, and I'm prepping the surface by scrubbing with detergent, sanding, and wiping it down with denatured alcohol, should stick ok, hope so, I haven't learned to like painting yet :)
    minno
  11. Mr Efficiency
    Just make sure the primer and finish coat are compatible. Consult the finish coat can's instructions about that. I know polyurethane finishes do not adhere well to alkyd undercoats.
  12. minno
    minno Junior Member
    Thanks for the heads up Mr.E
    they say it can be put on bare wood as is but recommend using 10% paint thinner for the first coat.
    Stay Safe
    BalzOut
