Hot dip zinc gaalvanized steel boat
Discussion in 'Metal Boat Building' started by tojeres, Dec 14, 2019.
  1. tojeres
    tojeres New Member
    Hi
    Does anybody have experience with hot dip galvanized steel whole boat ?
    regards
  2. jehardiman
    Likes: 1,515, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    That would be a huge and very expensive dip tank (remembering that the tank must be heated to the melting temperature of zinc). I'm sure you could probably find someone with a tank that could possibly fit a 2-2.5m hull (check the guys making cattle watering troughs), but nothing larger. Also remember that HDG results in a significant lowering of the strength of the steel. Plasma/thermal sprayed zinc has been around for more than 30 years and is the way it is normally done. Note that making repairs to thermal sprayed steel as its own issues.
  3. tojeres
    tojeres New Member
    Thank you for the opinion. Yes, HDG has to be done professionally in a factory. Regarding lower strength, I think it is negligible. I assume boat would be more sensitive to corrosion on scratches outside of a hull and less sensitive to corrosion inside a hull.
    I was not aware of thermal sprayed zinc. From other threads I see it is sucessfully used. I assume it is similar to HDG and therfore HDG seems good option.
  4. gonzo
    Likes: 2,412, Points: 123, Legacy Rep: 2031
    You could use Thermal Spray. It uses a flame to melt the metal to be deposited and heats the base metal.
  5. Wynand N
    Actually, a steel hull usually rusts from the inside out...think condensation.
    If possible, a hot dip hull plates would distort badly. I used to get some large tanks dipped and plates warps from the heat and it is safe to say a boat hull would act the same way.
    HDG like "jehardiman" suggests is the best way to go and I used it on a few hulls with great success.
  6. pauloman
    pauloman Epoxy Vendor
    aluthane - an alumium filled MCU coating is commonly used to 'replace' failing galvanized surfaces in the field (like stock tanks, metal roofs, fences, farm equipment etc.) It would be as close as you can come with a brush on coating. Uses a lot on aluminum boats too. see epoxyproducts.com/aluthane.html
    PAUL OMAN MS MBA Progressive Epoxy Polymers, Inc.
    A.K.A. “Professor E. Poxy” -- "The Old Goat" -- "Epoxy Guru"
    Epoxies since 1994
    Member: NACE (National Assoc. of Corrosion Engineers)
    SSPC (Soc. of Protective Coatings)
    info@epoxyproducts.com 603-435-7199
    www.epoxyproducts.com --- www.epoxyUSA.com
    MEMBER - BETTER BUSINESS BUREAU (buy with trust)
  7. Barry
    Likes: 649, Points: 113, Legacy Rep: 158
    Barry Senior Member
    At the low temperatures of HDG 850 F and the first major phase change in the carbon steel alloy probably found in steel hulls occurring at around 1400 degrees F, there should not be a reduction in the strength of the steel
    As the hull would not be in the tank very long, at this low temperature and the hull may be thicker than the large tanks that you had dipped, there should not be too much distortion BUT as Ad Hoc has presented the preferred/proper/meeting
    various standards construction method for steel/aluminum boats is to roll the plating to the precise shape before welding. This is so the plating is not under an induced load/stress during the construction and after the construction.
    Often small boat and perhaps even larger boats builders will take a flat plate and bend it manually to conform to slight curves, ie building in stress and then do a weld up. If this type of constructed hull is then heated for a period of time
    there may be a chance that the pre stressed condition allows the curvature to change/distort.
    Welding by itself introduces stresses due to localized heat at the weldment. On some type of structural components, these stressors can be relieved by bringing the steel up to around 650 F for several hours.
    So with HDG, there may be a slight reduction in these stresses, but due to the short dip time, it is probably insignicant
    But as Jehardiman stated, it would be difficult to find a tank large enough to dip a complete hull.
    As an aside, you have to be extremely careful when welding zinc'd? steel. With an arc a particular gas is given off which will make you extremely ill so proper ventilation is required, free air respirator preferred
  8. Mr Efficiency
    That's something I was unaware of.
  9. Barry
    Barry Senior Member
    I need to amend my comment above to include gas welding as well as arc welding. The vapor that is given off is ZnO, Zinc Oxide and can give symptoms similar to the flu in a short interval but longer serious health
    risks when exposed for a long time I had only mentioned arc welding originally
  10. Mr Efficiency
    Zinc oxide is toxic ? It is the ingredient in zinc creams, but inhalation may be another matter.
  11. Barry
    Barry Senior Member
    Evidently,
    I had an experience with this brazing on a hot dipped fuel tank. That is why I included it in the post, and then googled Health Risks Welding Zinc coated metal, lots of papers on this
    And of course people working over tanks doing the work are also impacted
  12. Manateeman
    Likes: 1, Points: 8
    Manateeman Junior Member
    Hi. Welders thought it was like the flu but zinc is not the only problem...lead is present.
    I never touch galvanized with TIG or brazing.
    It’s not the flu.
  13. ExileMoon
    Likes: 21, Points: 8, Legacy Rep: 45
    ExileMoon Junior Member
    The overall hot-dip galvanizing of the entire ship seems to be an impossible project. Because there is no such large galvanized pool, even if there is, the hull will be destroyed due to severe thermal deformation.
    In China, some powerful shipyards use a thermal spray method to galvanize the entire ship. This method is to use high-temperature and high-speed airflow (like a jet engine) to carry the zinc powder out and melt it, and then impact on the surface of the steel plate to cover it. This method is very effective. It can be injected powerfully even in narrow gaps.
    This method is effective not only for newly built ships, but also for repairing old ships.
  14. ExileMoon
    Zinc is a metal with a high evaporation pressure (similar to quicksilver). After melting, it is more volatile than other common metals to produce zinc oxide particles, which can lead to inhalation and lead to zinc poisoning. To avoid this phenomenon requires strict respiratory protection measures.
    After inhaling zinc oxide fumes, there is sweetness in the mouth, thirst, itchy throat, loss of appetite, fatigue, tightness in the chest, and sometimes dry cough. Onset after 3 to 6 hours, first feels cold and then chills, followed by high fever, accompanied by headache, tinnitus, fatigue, and sore limbs.
    Fortunately, this kind of poisoning usually does not cause permanent damage and usually heals after 2 weeks.
    The most common components in zinc pools are zinc and some aluminum, not the kind of poisoning caused by lead.
    What should be more vigilant is the other:
    Cadmium poisoning
    Cadmium is plated on the surface of steel to prevent corrosion. It is very common in the United States, especially in some high-performance bolts. Sometimes confused with zinc.
    China has closed a large number of small hot-dip galvanizing tanks due to environmental protection issues, because these factories lack the funds to deploy comprehensive protective measures. Only some large factories can be retained, they have a complete training system and protective equipment, and they are supervised.
    If everyone encounters galvanized sheet during welding, pay attention to this problem and wear at least N95 breathing mask.
  15. Mr Efficiency
    Strange about the toxicity of zinc oxide, which of course is the ingredient of zinc creams, I guess anything is toxic if enough is ingested.
