honduran mahogony
Discussion in 'Wooden Boat Building and Restoration' started by phillip, May 8, 2005.
  1. phillip
    phillip Junior Member
    Hi! I have made belaying pin racks and cleats out of honduran mahogany. I also carved out a coaming for the companion way. Now I'm wondering if I'll be able to steam this wood enough to bend it ? Will this wood take a steamed bend?
    Thanks Phil
  2. marshmat
    marshmat Senior Member
    Depends how tight the bend is.... if you steam it enough and bend it slowly enough, mahogany can bend fairly well, but only to a point.... perhaps a 2-3 foot radius for every inch of thickness is as tight as I would ever try to go with steaming, but that's just a guess....
  3. phillip
    Thanks Matt: Probably not a great choice of wood; But it will look good if it'll go.
    Phil
  4. gonzo
    Likes: 1,726, Points: 123, Legacy Rep: 2031
    It bends fair. Mahogany won't make a tight radius like oak. Make sure you soak the wood for two or three days before steaming and it won't split.
  5. phillip
    Would it help to heat the coaming on the inside of the radius while jigging it?
    Thanks Phil (soak/steam/heat/?)
  6. gonzo
    It is better to heat the outside of the curve. That is the part of the wood stretching. I use a propane torch and keep it wet with a brush and water. A helper makes it easier.
  7. phillip
    Thank you for the response and sharing your knowledge.
    Phil
