hi all, long time lurker, first post. I've recently acquired a new to me project, an Allegra 24 hull and deck kit. I've done a good bit of research and reading, (skenes , gougeon bros, riggers apprentice, and many others) all in order to help me determine some best practices and rig decisions and other design and fabrication decisions in order to proceed. I'm planning on building a wooden box mast and I have the basic dimensions worked out for a fir spar . One thing I'm currently looking at however is whether the addition of foam to the hollow box spar would be worth considering from a structural perspective. I have access to some free fomular 250 EPS foam which is pretty sturdy stuff as foams go and my thought was that epoxying the foam inside would stiffen up the mast considerably without adding much weight and help to spread loads. I was also trying to determine if by adding foam I could reduce the thickness of the wood slightly. I've seen in other forums not to add fiberglass to the inside of the mast as it will bend / compress prior to the wood and therefore not lend anything to the structure and perhaps it's the same answer with the foam? Perhaps the answer is in increasing the dimensions of the mast and adding the foam and reducing the skin thickness (i know you can do that with just the wood). Anyways, I'm kind of at a loss as whether to keep looking into this or not and figured I would reach out to the group here. I can't seem to find anyone else using a similar technique. Any thoughts on if this would be worth while or just a waste of time and resources? Here's a pic of what I'm thinking. Thanks!!
