DR is Dead Reckoning or Deduced Reckoning. It is keeping track of your position between fixes as best you can by monitoring/recording course and speed and possibly predicted current sets. Some navigators call it estimated position EP if you include current in the calculation. In the days prior to GPS/Loran/Decca which give continuous fixing of position, you had time between fixes which was DR time. Typically ships sailing by the sun and stars took position lines when possible. A position sun-line say at 9 am can be 'run up' using your DR course and speed to another sun-line ( now a different height and different bearing ) say at 2pm. Where they intersect you have a "running fix".
If you do not have a decent fix for a bunch of hours or days because of weather, your DR might have a large error. You simply do not know where you really are. Approaching land, making a landfall in those conditions was scary to say the least.
GPS can have errors sometimes, or Charlie could have read it wrong. Fatigue??
GPS does not eliminate the danger but massively reduces it. People can and will plow into the shore from time to time, despite all the advantages we have today
