Here are some links that might help you: Construction Methods - Foam Core Construction https://smalltridesign.com/Trimaran-Articles/Construction-Methods/Foam-core-over-male-or-female-mould.html
Since the foam has little tensile strength and is just there for compression and shear strength to hold up the laminate the joints don't matter structurally, just how well you can bend them. Neither if the strips are longitudinal or vertical for that matter. I'm a beginner with zero experience but just wanted to let you know in case you're confused about that. Might save you time if you use thermo-forming and larger patches for example.
