help with outdrive
Discussion in 'Sterndrives' started by stevenance, Jan 6, 2010.
  1. stevenance
    stevenance New Member
    hi im new to the forum.
    im looking for all the help i can get on the right outdrive
    i have been told to only use the volvo duel prop..
    but no one can tell me witch one.
    i have a 26' stamas hardtop and i am putting in a cummins 4cyl.
    turbo diesel with about 200hp
    thanks for any help you can give
    Likes: 2,275, Points: 123, Legacy Rep: 2031
    What outdrive do you have now?
  3. stevenance
    nothing right now
  4. gonzo
    Mercruiser uses Cummins engines so it should be a straight hookup. With Volvo you will have to make adaptors. Diesel outdrives have an epoxy coating in the exhaust because of the more corrosive fumes.
  5. fasteddy106
    Likes: 17, Points: 0, Legacy Rep: 171
    fasteddy106 Junior Member
    Go with the Merc unit. They are inexpensive, reasonably reliable, not a lot toys & whistles and your grandmother knows how to work on them.
