WindBoatMan
New Member
- Joined
- Jan 11, 2013
- Messages
- Reaction score
- Location
- United Kingdom
Hi there,
I've been using this excellent forum as a resource for a while and using the advice shared to help with my project. I have spent the last 2 years restoring a 1938 40ft teak hull river cruiser and am in the midst of the big rewire. I have attached a couple of pics of the project.
I'm pretty knowledgeable with the 12v side of things and have been re-wiring with a friend who's an auto-electrician checking over my work as I go along.
I have a bit of a dilemma with a prestolite alternator to solve and was wondering if anyone may be able to shed some light on this.
Here's a link to the literature on the alt -http://www.prestolite.co.uk/literature/alts/G770_8mr2049.pdf mine is the same but a 90amp model.
I want to connect this alt to a new external regulator, a PDAR unit made by Sterling Power. I know that this is a -ve field Alt and need to connect the external reg to the -ve field wire on the back of the alternator. I wanted to find out if I was going to be lucky and that one of the existing external connections shown in that PDF is a direct connection to the negative field brush? Otherwise, if not, I have to crack the existing regulator and solder a wire onto the negative field (the wire labelled as the excitation wire seems to be already connected to the brushes?!).
Many thanks in advance all.
Adam.
Adam.
