HELIPAD for yatch retrofit
Discussion in 'Boat Design' started by AnneY, Aug 9, 2011.
  1. AnneY
    AnneY Junior Member
    Sir/Ma'am
    Good day!
    I am an engineer currently involve in a naval ship conversion project. We are currently considering the addition of an helipad to the retrofit of the naval ship to a yacht but research is necessarily to verify if this is possible. As a part of our research, we are trying to find information regarding the rotor clearance/deck clearance required for different size and model of helicopters, particularly twin engines helicopters that can accommodate 5-7 passengers.
    If there is any information you can give us or at least point us to the right direction, you can reach us through this email.
    Any assistance from you will be greatly appreciated.
    Regards,
    Anne Yumul
    Civil Engineer
  2. Frosty
    Frosty Previous Member
    I might suggest your on the wrong Forum. Theres are guys here will gladly advise you but after being here for donkeys years I know not of one that has helicopter experience.
    I noticed your a civil engineer and not naval nor did you include your email as you said you had. If I/ we are to accept you question as credible... well some things don't kinda add up.
    Perhaps contacting the helicopter manufacturer for rotor clearance, but living in a marina with a few helicopter clad vessels they don't normally fly them right up to the final position. Im sure the pilots will explain "walk"
    Some ostentatious owners squeeze on helicopters that should not be there. The tip to boat fixture is critical.
    This distance is refered to as "F" as in 1 meter tip clearance would be F'n close.
  3. Ad Hoc
    Likes: 855, Points: 113, Legacy Rep: 2488
    All you need to know, for now at least, is in CAP 437. (google it)
  4. AnneY
    AnneY Junior Member
    Thank you for the responses.
    If this would be of any use, this is my email address: incubus_0110@yahoo.com
    I am working for a private company whose owner bought a naval ship and wants to convert it to a private yacht. I know I am a civil engineer and no where knowledgeable about naval architecture but as what all employees need to do, I need to accomplish anything my employer asks me to do. And one of the task assigned to me was to research about boat retrofits.
    I joined this forum in the hopes of gaining knowledge or at least being more familiar with boat architecture and other topic related through posting and forum discussion.
  5. Ad Hoc
    AnneY
    Well, i hope your client has lots and lots of money and plenty of patience!
    Where abouts in Phili are you doing the converstion?
    (I used to work in Phili).
  6. Frosty
    Clarke air base probably down Feilds Avenue. Now don't tell me you don't know where that is.
  7. AnneY
    AnneY Junior Member
    I know Clark Air Base. Actually I live just one town away from Clark.
    The naval ship is now docked at Bataan and is currently undergoing testing and inspection.
  8. Frosty
    Yes I know it well too, I know lots of chrome pole polishers.
  9. ABoatGuy
    ABoatGuy Member
    The LY2 rules have a section on helicopters. Rule is for commercial yachts in the UK, but good reference for others.
  10. Stumble
    Stumble Senior Member
    Anne,
    You might want to contact the builder of the vessel. A lot of navy ships do have helicopter capability in some configurations but not others. It is possible that they already have a design brief to have a helipad as an option.
    Can you give the class of vessel, and navy it's from? This might help a lot. Some of the researchers here are a living breathing knowledge base of all things nautical.
  11. JosephT
    Likes: 107, Points: 43, Legacy Rep: 218
    JosephT Senior Member
    As an aeronautical engineer and former member of US Marines helo squadrons (we operate helos on flight decks), there several factors to consider:
    1. Ship design: Need more info on this ship to comment. Unless the ship design allows such a retrofit this could be a very risky modification to say the least.
    2. Helo specs: Need more info on the helo moke/model (e.g. weight). Most sea based helicopters are built from the ground up for sea conditions. All aluminum arts are treated (e.g. alodine), primed and painted to ensure minimal corrosion. Otherwise, the aircraft structure and systems will surely corrode which leads to malfunctions and safety issues.
    3. Excellent training: Ships move so much training is needed to locate the moving boat and land on it while under way in good or bad weather. Generally, flight ops are halted in bad weather. Also, all flight crews should be excellent swimmers and ideally be life guard certified (comes in handy when rescuing passengers if pilots need to set helo down in the water).
    4. Maintenance shop: Aside from the landing pad, the yacht should have a workshop and space to store spare parts. If the helo is to be operated at sea for any given period of time it will need this type of support.
    5. Fresh water spray down: At the end of each day the helo should receive a fresh water spray down on deck to rinse salt from all helo parts (skins, flight control actuators, engines, etc. Again, most helos operating at sea are built for such operations. They include water ports to connect fresh water hose to make engine wash down easy.
    6. Obstacles on deck: On deck, generally speaking helo rotor blades should have 3x spacing from vertical obstacles on the ship (e.g. ship tower). This generally allows safe operation. Pilot skills are also critical. Any pilot operating on a ship should be well trained to land on a small, moving landing pad. I would suggest you dialogue with Phillipine Navy pilots. Most likely the owner will hire one of them to fly crew.
    This is no doubt a major modification to a ship. Be sure to do all your homework or lives will be lost. Even with ideal conditions operating a helo on deck if a ship is very risky.
  12. AnneY
    AnneY Junior Member
    Good day.
    Thank you for your responses.
    I will forward them to my superior.
    As for the class of the navy ship, we were not given the full specs of the ship for confidentiality reasons.
    All we know is it is one of the seven vessels of the British Royal Navy have been named HMS Bulldog.
  13. Frosty
    Bulldog class survey vessel
    From Wikipedia, the free encyclopedia
    Jump to: navigation, search
    Class overview
    Name: Bulldog class coastal survey vessel
    Builders: Brooke Marine, Lowestoft
    Operators: Royal Navy
    Preceded by: Hecla-class survey vessel
    Succeeded by: Echo-class survey ship
    Built: 1967–1968
    In commission: 1968–2002
    Completed: 4
    Retired: 4
    General characteristics
    Type: survey vessel
    Displacement: 1,050 long tons (1,067 t)
    Length: 189 ft 6 in (57.76 m)
    Beam: 37 ft 5 in (11.40 m)
    Draught: 12 ft (3.7 m)
    Propulsion: 4 x Lister Blackstone diesel engines
    660 bhp each
    2 x shafts
    Speed: 15 knots (17 mph; 28 km/h)
    Range: 4,000 nautical miles (7,400 km) at 12 knots (14 mph; 22 km/h)
    Boats and landing
    craft carried: 2 × 9.5 m survey boats
    Complement: 4 officers
    34 ratings
    Sensors and
    processing systems: 1 × 1007
    Armament: None (fitted for 2 x 20 mm Oerlikon GP)
    The Bulldog class was a four ship class of survey vessel in service with the Royal Navy from the late 1960s until the start of the 21st century. Initially designed with service overseas in mind, they spent most of their careers off the British coast. A fifth ship was subsequently built to a modified design to support them in their activities. Decommissioned and sold off at the end of the 20th and start of the 21st centuries, they have continued in service as civilian vessels, with some being converted to private yachts and others entering other commercial sectors.
    Contents
    [hide]
    * 1 Design
    * 2 Careers
    * 3 Ships
    * 4 Notes
    * 5 References
    [edit] Design
    The Bulldogs were designated as coastal survey vessels, and were a variant of the earlier Hecla-class designs.[1] All four ships were built by Brooke Marine utilising merchant hulls.[1] The resulting design was stable in a variety of sea conditions, and the class was considered to be good seakeepers, with an all-welded construction, a bulbous bow and a high flared forecastle.[1] Anti-rolling tanks and twin rudders were also fitted. The ships used eight-cylinder diesel engines powering two propellers and were fitted with specialised echo-sounders, Marconi Hydrosearch sector scanning sonar and a variety of sonar and radar. In addition they carried two small surveying boats, fitted with echo sounders.[1]
    [edit] Careers
    They were intended to serve overseas in pairs, with four ships being ordered in the late 1960s: Bulldog and Beagle; Fawn and Fox.[1] Despite the original intention to use them overseas, the growth of the exploitation of the oil and gas reserves in the North Sea from the 1960s onwards led to them spending most of their time engaged in survey work off the British coast.[1] The increased demand for their services led to the Admiralty ordering a fifth ship to a modified design in the 1980s, which became HMS Roebuck.[1]
    Fox was the first of the class to leave service, being sold to commercial interests in April 1989.[2] Fawn was paid off in October 1991 and sold to interests in West Germany to become an offshore support vessel of the West African coast, and the China Sea under the name Red Fulmar.[3] Bulldog was paid off on 26 July 2001 and sold the following month for conversion to a luxury yacht. A major fire broke out while she was moored at Nelson, New Zealand and the conversion was not completed.[4] Beagle was the last to leave service. She was paid off on 7 February 2002 and sold the following month to a yacht company at Poole for conversion.[5]
    [edit] Ships
    Name Pennant Launched Completed Commissioned Fate
    Bulldog A317 12 July 1967 1968 21 March 1968 Paid off on 26 July 2001
    Beagle A319 7 September 1967 1968 9 May 1968 Paid off on 7 February 2002
    Fawn A325 29 February 1968 10 September 1968 4 October 1968 Paid off in October 1991
    Fox A320 6 November 1967 1968 11 July 1968 Sold in April 1989
    [edit] Notes
  14. masalai
    masalai masalai
    http://www.btinternet.com/~warship/Today/hecla.htm
    Maybe the original did not have a helicopter capability, hence the change noted in BOLD, for their replacement on decommissioning...
  15. AnneY
    AnneY Junior Member
    We are currently confirming the helicopter model the owner wants to land in the yacht. With the helicopter model identified, hopefully we will be able to research for its specs. Most probably it will be a twin engine Bell model that can house more than 5 passengers excluding the pilot.
    I was also able to research about retractable helipad that can be custom fitted to a yacht. Headland is the name of the company. But this might be a expensive option considering there is a need to outsource a designer/consultant for the fitting.
