I want to build a couple simple 7' long floats for a slow trimaran sailboat. I looked at some of the different techniques that you see on YouTube etc. One of the techniques was intriguing. Basically, you make your own prepreg. Start with dropcloth material that epoxy won't stick to, put your glass layers on top of that. Impregnate the glass and put another dropcloth on top then squeegee out the excess glue. Now you have a simple panel. What I'd like to try is cutting the prepreg into a rectangle while still wet but leave tabs every foot or so. Then suspend the whole thing from the ceiling to cure. Voila, a half pipe which could be the bottom of the float (shape should be a catenary). Has anyone used this technique? :idea:
