Graeme Delaveau multihull design
Discussion in 'Multihulls' started by redreuben, Oct 3, 2009.
  1. redreuben
    Likes: 224, Points: 63, Legacy Rep: 349
    redreuben redreuben
  2. boat fan
    Likes: 17, Points: 18, Legacy Rep: 435
    boat fan Senior Member
    Nice link thank you
  3. simon
    Likes: 3, Points: 18, Legacy Rep: 70
    simon Senior Member
    Does anyone have experience with his designs? Nice looking designs. Are the flat bottoms prone to slamming?
    Simon
  4. redreuben
    redreuben redreuben
  5. jamez
    Likes: 65, Points: 28, Legacy Rep: 231
    jamez Senior Member
    Hi Simon, I'm building a Delaveau 25' Tri. Given that the flat portion of the main hulls ie. the bottom are so narrow I doubt slamming would generally be an issue. Flat bottom is not an unusual configuration for a tri main hull. Most common would likely be the Tremolino possibly followed by Marples Seaclipper 28. Both well regarded designs.
  6. catsketcher
    Likes: 165, Points: 63, Legacy Rep: 790
    catsketcher Senior Member
    Flat bottoms make the rocking world go round
    I have a mate with Schionning Wilderness. It has a flat bottom and slaps a lot. He is considering putting a curve on the front section. I think a tri would have less of an issue than a cat as a tri leans a lot more than a cat so a flat bottom is not flat when sailing hard.
    cheers
    Phil
