Glass fiber cement
Discussion in 'Materials' started by TANSL, Jan 8, 2018.
  1. TANSL
    Likes: 636, Points: 123, Legacy Rep: 300
    Cement reinforced by round rods of fiberglass instead of traditional round steel rods. What do you think of this technique?
  2. rwatson
    Likes: 340, Points: 83, Legacy Rep: 1749
    rwatson Senior Member
    We have been talking about it for the last 3 weeks, but with basalt rods, because the cement adheres better, and you can buy heavy duty mesh. Here is a video of the process
  3. jorgepease
    jorgepease Senior Member
    just regular glass fibers will do that flower box in the video in 3/4 ich
  4. PAR
    Polyester strands and rods are very common in the building industry. A 30% material savings can be usually seen on well designed concrete structures.
  5. TANSL
    Yes, in civil construction takes time being used.
    I was wondering if, given its inalterability against corrosion and the absence of magnetic character, it would have already been applied to shipbuilding. In this forum we have talked about cement reinforced with steel rod, in naval construction and had not mentioned, as far as I know, the fiberglass rod.
    It would also be interesting to know glass-asbestos opinions and comparisons
  6. dsigned
    Likes: 13, Points: 18
    dsigned O.R.C. Hunter
    I started a thread a while back about this:
    Ok everyone, it's that time of the year again: time to talk about concrete https://www.boatdesign.net/threads/ok-everyone-its-that-time-of-the-year-again-time-to-talk-about-concrete.59200/
    I actually just finished my second test panel with chopped glass fiber. I think my next one may be PVA fibers (poly vinyl alcohol).
