Geodesic Engine room
Discussion in 'Boat Design' started by rfleet1066, Mar 21, 2022.
  1. rfleet1066
    Likes: 35, Points: 28, Legacy Rep: 46
    rfleet1066 rfleet1066
    The Sebastian Marie is under constant development. She has been fitted with a Geodesic engine room which rotates with the drive unit. Also, a 200 gallon hot tub is fitted to the deck. We exchanged the little Casita Camper for an adult-sized Airstream . The forward Tent now has a full sized Vulcan stove, two deep fryers, and a flat screen video. We also fitted her with a 14 KW keel cooled generator upload_2022-3-21_5-22-28.jpeg upload_2022-3-21_5-26-0.jpeg upload_2022-3-21_5-28-4.jpeg upload_2022-3-21_5-28-35.jpeg upload_2022-3-21_5-32-37.jpeg
    gonzo likes this.
  2. bajansailor
    Likes: 1,840, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    @rfleet1066 if you click on the 'edit' button in the bottom left of the post, you should be able to remove the excess photos.
    What will you be using the Sebastian Marie for? Will you be living in the bus and doing commercial catering with the tent?
  3. rfleet1066
    This vessel has the only purpose of amusing me.
    Lloyd Too likes this.
  4. philSweet
    Likes: 640, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
    Some people are more easily amused than others. You appear to have the bar set fairly high! Good work. A camo throw ring is a bit peculiar, though.:D
  5. rfleet1066
    Oh, I guess I should show the land dinghy.......... upload_2022-3-22_5-23-45.jpeg
  6. wet feet
    Likes: 624, Points: 113, Legacy Rep: 124
    wet feet Senior Member
    It has exceeded it's design purpose then,because it amuses me too.It makes a refreshing change to see a design without strong ties to commercial or performance factors.
  7. rfleet1066
    When a designer ignores convention, there is an opportunity to snatch art from the jaws of science
    cracked_ribs and Will Gilmore like this.
  8. Scuff
    Likes: 44, Points: 28, Legacy Rep: 10
    Scuff Senior Member
    I'd like to see the drive unit. Cool boat!
  9. rfleet1066
    This is the drive unit before being fitted with the dome.
  10. rfleet1066
    You are in a unique geographic position to see the vessel in person. She is docked in New Kent.
  11. Scuff
    Scuff Senior Member
    I was thinking the same thing
  12. rfleet1066
    You are welcome to visit and tour the vessel.
    Ryland Fleet
  13. rfleet1066
    I built this vessel twelve miles from the site of launching. It is designed to be disassembled and moved in pieces or using the lifting lugs and certified slings, picked up in one piece. I built buggies to move the hull sections. The local Sheriff's Department turned out to escort us and control traffic. It was assembled at the launch site. I fitted her hulls with phone pole cradles with carpet nailed to them, saturated with dish soap. The poles were made to extend ten feet out in the front, and held with nylon ratchet straps. Then this assembly was placed on transverse poles, as rollers. We then pushed her down the slope with an excavator. The poles in front dug into the mud as planned. The I cut the straps and with a gentle push she slid on the lubricated carpet into the water.
    Be advised, when I got into this project, I knew nothing about boats. My ignorance enjoys a good heckling, so have at it fellows! This forum was instrumental as a resource and I cannot thank you all enough. The vessel now, three and a half years later has over 4500 river miles traveled, and going strong.
    Ryland Fleet
    BlueBell and bajansailor like this.
  14. Scuff
    Scuff Senior Member
    I 2nd your comments on this site .. there is a wealth of information and expertise here.
  15. Squidly-Diddly
    Likes: 188, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
    Great minds think alike. See my Gallery for my modular cat concept.
