Generally speaking: constant V preferred over warped.... NO DISTURBANCES in front of intake and within minimum 150% of intake width!
Warped bottom
Modified V
Deep V modern 19' bow riders
full length constant deadrise V
Assuming a boat about 20' & V8
Mat-C: You deduce the shape correctly--it is a chunk taken out of the bottom of the boat. I did that on the advice of the engineers at Hamilton Jet. They said that in their experience, this type of shape works extremely well. The trick is that the slope of the chiseled front forward of the inlet flat has to be a small incline, and what I show passed muster with Hamilton. A gentler slope might be better for the jet, but worse for the ride--it would cut into the V-bottom too far forward. The boat likes to ride on a V-bottom, not on a flat. So my shape was the best compromise. The slope is gentle enough that, considering the running trim angle and hull depth when running, there is still positive hydrostatic and dynamic pressure into the jet inlet.I know this is an old thread, but I was hoping that Eric might answer a question or two regarding the bottom shape of the Cherubini that he linked earlier in the thread... (cool boat BTW)
From the perspective view and the side (below) it looks like you have effectively taken a chunk out of the bottom to produce a flat for the jet intake. Is this how it is typically done in a 'deep-vee' configuration? I would have though it would create a bit of turbulence in front of the jet, as well as a possible area of 'negative pressure'.
You're welcome.Thanks Eric
Here is a pic of a Haines Hunter 1800S, many of which were built in the '80's. They are still very highly regarded for their handling and rough water performance. Most were outboards, though some were also fitted with sterndrives and I think even a few jets. I post it only because it has the kind of 'pad' that I was referring to....
Thanks again for the insight![]()
To both Speedboats and Mat-C,
...we elected to use the Mercury jet pump which is a really neat compact little unit, although gasoline instead of diesel. The market did not accept it that well, ...
