Galvanic corrosion
Discussion in 'Materials' started by urisvan, Jun 11, 2020.
  1. urisvan
    Likes: 5, Points: 18, Legacy Rep: 53
    urisvan Senior Member
    i have an aluminium mast of my dinghy and i need to attach stainless fittings on it by rivets. Before i was using "tefgel" to prevent galvanic corrosion, i was also putting tefgel on rivets too. Actually it was working fine...
    What else can i use instead of tefgel??
    Regards
    ulas
  2. bajansailor
    Likes: 1,840, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    fallguy likes this.
  3. Blueknarr
    Likes: 462, Points: 83
    Blueknarr Senior Member
    I've cut spacers out milk jugs.
    fallguy likes this.
  4. urisvan
    Hi Blueknarr,
    But what about rivets?
  5. Blueknarr
    Didn't claim it was a perfect system
  6. David Jones
    Likes: 8, Points: 3
    David Jones Junior Member
    Your stainless rivets are more noble than your aluminum mast and the area ratio is in your favor. It may not be "perfect" - but it works.
    dj
  7. fallguy
    Likes: 1,985, Points: 123, Legacy Rep: 10
    okay, hold on a second
    would it be preferred for the hole or the rivet to fail?
  8. Will Gilmore
    Likes: 531, Points: 113
    Will Gilmore Senior Member
    The nature of galvanic corrosion was first discovered when ships were plated with copper sheeting. They were using iron bolts to hold the copper sheeting on. When ships were brought out of the water to have their plating repaired, they noticed that some suffered more corrosion than others, which often suffered from almost no corrosion around the iron bolts. The difference, it was discovered, was that suppliers of the copper sheeting would cover the copper with heavy paper to protect it. Some shipyards would peel the paper off before bolting the copper to the bottoms, while other yards left the paper on and bolted right through the paper before cleaning the paper off. The bottoms that were bolted through the paper trapped just enough paper between the bolt heads and the copper sheeting to isolate the two metals from each other. It really doesn't sound like it takes much to isolate from galvanic corrosion. It is also important to reduce contact with the electrolyte. Two dissimilar metals don't generally corrode without an electrolyte. Mastheads see little salt spray and dry quickly in the sun and wind. A masthead should have less problems then bowrails, for example.
    -Will (Dragonfly)
  9. Will Gilmore
    What David is saying is that the more noble metal pulls electrons from the less noble metal, but it can only do that at a given rate determined by a number of factors including path to ground, how disparit the two metals are from each other and how much material each is made up of. A small amount of the more noble metal surrounded by a much larger amount of the less noble metal will result in a very slow corrosion rate. All the surrounding aluminum material contributes to feeding the relatively tiny steel bolt. Also, your mast isn't pure aluminum, it's an alloy that has much more resistance to corrosion than pure aluminum.
    -Will (Dragonfly)
