Full size plans
Discussion in 'Wooden Boat Building and Restoration' started by Kaptin-Jer, May 11, 2010.
  1. Kaptin-Jer
    Likes: 18, Points: 0, Legacy Rep: 206
    Kaptin-Jer Semi-Pro
    Does any one know of a taditional small sailboat plan other than the Haven 12 1/2. That does not require lofting?
  2. alan white
    Likes: 122, Points: 0, Legacy Rep: 1404
    alan white Senior Member
    Of many hundreds of small sailboat plans out there, the Haven -12 1/2 is an expensive little yacht that can take years to build. Is the 12 1/2 the type of boat you want to build, or something lighter/cheaper/easier?
  3. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    Alan
    Yes, a Herrishoff / Alden type vintage boat is what I am looking to build. I have lofted in the past, but I cheat and use the computor then plot full size, but it never fails, something is always off and fairing is a nightmare. I just finished restoring a 38' Benny, but health, money and a nagging wife have restricted me to whatever I can build in my garage. "Your not giving that marina one more dime". I like the Haven, but I was looking for a choice.
  4. alan white
  5. uncleralph
    uncleralph Junior Member
  6. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    Both boats are nice. But if I'm going to spend 2+ years sweating in my garage it will have to be for something worth the time and money. I once built a Roberts 27' plywood walk around. I did not feel that I was building a real boat the right way. So far the best (traditional) boat I have found is the Haven. I can't convince my wife that a boat like a racing T boat would be fun. She says it's to much work to sail. --guess we all gettin old.
  7. alan white
  8. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    Gartside has some nice boats, but both sites say that lofting is required. If they would give out the CAD file I could plot the lines full size, but I know just enough not to attempt lofting the old fashion way. Been there done that-- it wasn't pretty.
  9. alan white
    Maybe if you can't find the right boat with full size patterns, someone could loft it for you. A small hull wouldn't be too expensive and you could get your own patterns from the loft floor.
  10. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    That's not a bad idea. That opens up a lot of choices. Are you aware of any design similar to a Dragon, scaled down from 30' to @ 20'? I always wanted a Dragon....
  11. alan white
  12. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    Yes
    The Dark Harbor is a great boat. But a really tough build with a difficult fixed keel, and not too much more than offsets to use. I have always liked that design, but I'm a little intimidated by it, also.
  13. alan white
    You won't get into anything under 20 ft with that look. You might do plywood, hard chine or multi-chine. Easier in every way. Have you heard of Phil Bolger's Chebacco series? There are two versions, glues lapstrake and plywood. The plywood model is, to my eye, the more elegant. In fact, those chines accentuate the curves in a way the lapstrakes cannot do.
    1900 lbs, trailerable, probably you could get by without lofting.
    http://dory-man.blogspot.com/2009/03/chebacco.html
  14. alan white
    I think Bolger's Chebacco 20 plan set is available full size. Wonderful boat. The plywood version is the best looking.
  15. Kaptin-Jer
    Kaptin-Jer Semi-Pro
    But it is still a catboat. The Dark Harbor 20 by S&S is nearly a duplicate of the Finnish Dragon, but a 30' it's too big for a garage buid, but the 12 is ideal. It looks as good on a trailer as it does in the water. So we are down to a choice between a Haven or the 12. Lots of pros and cons with each to consider. I have to do a lot more research on the D.H. 12. That is my first choice, but I'm worried about the plans. I haven't found a web site yet dedicated to a build, but I'll keep looking.
