I missed that this is a 2-stoke not that it makes much difference with regard to carb rebuilding, but it does explain the black oil looking substance found in one carb making it less likely to be hose residue.
You can always take a fuel sample to make sure your hose is okay.
One other important thing I forgot to mention that some forget when replacing fuel supply line, is if you are using a typical auxiliary plastic tank, they usually have a prefilter at the pickup tube in the tank. The screen or even tube itself on this can go bad, get clogged, or disintegrate and end up in the fuel line sometimes even building up behind the ball valve at the disconnect restricting fuel flow or fouling the ball valve causing it to leak when disconnected. Since it usually spends the majority of time sitting in fuel, I find it’s always worth replacing as it also helps to keep crap in the tank and out of the bulb and ball valve.
Ignition troubleshooting is a matter of starting with the basics. Making sure the system is getting voltage, making sure the coils are good, wires, plugs, etc..
If it doesn’t turn over at all (assuming it is electric start) or won’t fire when pull started, check all ignition interrupt switches. Typically one at the shift linkage, maybe one for oil pressure, and the kill switch. A lot of times shift linkage gets worn and the switch can get out of sync with shift positions.
If it turns over or pull starts without producing spark, and you have power to the coils and ignition, and it’s not an interrupter switch, and the coils measure out, it could be ignition related.
Manuals are great to have, but a lot of this stuff is just basic troubleshooting.
I recently bought a motor that ran like crap off idle and made no power. Started fine and otherwise ran fine, however I noticed it would build crankcase pressure and was stinky and it would kick back a bit on a restart. I suspected a timing issue and remembered the previous owner mentioning he had the timing belt recently replaced and that the motor idled high and didn’t make the power it used to at high rpm. I immediately suspected that the timing was off and the motor was too far advanced and that the cogged belt must be off by a few teeth. Sure enough, I discovered the cam and crank were out of sync. So I removed the belt and put it back on with the cam and crank properly aligned, and it now runs and idles perfectly. Even smells pretty good!
Anyway keep at it and you’ll figure it out.
One important benefit of clean well adjusted carbs with regard to outboards, is it allows you to achieve a proper low idle which makes shifting much easier on the lower end.
How many times have you been at the ramp and heard motors idling way too high clunking in and out of gear, sometimes so badly you actually see the motor kick?
No thanks. I much prefer working on the top end rather than destroying the bottom end.
