FSI in Ansys workbench 14.0
Discussion in 'Hydrodynamics and Aerodynamics' started by arun_naval, Feb 6, 2013.
  1. arun_naval
    arun_naval New Member
    Hi ALL,
    I have just started my Phd in FSI regarding hydroelasticity of ships. The main concern is to establish a 2 way coupling between CFD(RANS) and ANSYS. So while going through the workbench i had a major doubt. This could be a little silly but hope you could guide me.
    I am using ANSYS 14 in the uni and i understand it is possible to do a 2 way coupling using FLUENT.While going through the steps i saw that once the 2 analysis systems are launched, and coupled the geometries are also linked. This is so that they are updated together right? In my case i think i will have to set up the geometry and meshing in ICEM as the meshing tool in DM is not so good, and then i can export to fluent. But if i import a mesh after that in the FLUENT analysis system the geometry link is gone and only the setup link shows. Is this Ok when i am doing a 2 way coupling? I mean is it necessary that i have to explicitly use the geometry and meshing in the Fluent workbench analysis tool or can i use any software for meshing and later load it?
    I am yet to read the manuals completely but before doing that and finding that i can't if you could guide me, i would be able to save a lot of time.
    Thanks
    Regards
    Arun
  1. Ashwin Gurjar
  2. tuhin.name
  3. mahmoud
  4. Mohsen
  5. Binh
  6. Thiago da Silva Lopes
  7. Charleenguyen
  8. puma xalxo
  9. ychodneker
