Freda - Oldest yacht on the US west coast
Discussion in 'Sailboats' started by JosephT, Jun 5, 2014.
  1. JosephT
    Likes: 107, Points: 43, Legacy Rep: 218
    JosephT Senior Member
  2. hoytedow
    Likes: 373, Points: 93, Legacy Rep: 2489
  3. CloudDiver
    Likes: 7, Points: 18, Legacy Rep: 40
    CloudDiver Senior Member
    I love the 'engine turned' brass instrument panel. Really nice touch when putting a modern Aux Engine Gauge Panel into a classic wooden yacht. Anyone with a small drill press fitted with a fence and a steady hand can do this. For the smaller patterns you can use a wood dowel with some abrasive polishing compound. The best tool is a felt bob used by Gunsmiths and Jewlers with valve lapping cutting oil. There is a spring loaded holder you can get to chuck up in the drill press which assures even pressure on the felt fob, $40. I've only done larger patterns for decoritive panels using Scotch Brite type polishing pads, the same seen in this video;
    http://www.youtube.com/watch?v=5KmnVLU304w
    You can get various size Felt Bobs from Mcmaster Carr, also prepreg with polish;
    http://www.mcmaster.com/#felt-polishing-bobs/=sohwg2
    Here is the spring loaded holder from a Gunsmith Supply Store, they also have SS wire engine turning brushes (bristles or full area, not just circumference like wire brush cups)
    http://www.brownells.com/gunsmith-t...ols-accessories/e-t-brush-holder-prod607.aspx
