Formula to compare 2 structures
Discussion in 'Boat Design' started by longcours62, Feb 12, 2014.
  1. longcours62
    Likes: 5, Points: 0, Legacy Rep: 47
    longcours62 Junior Member
    I will try to explain with my poor English.
    On a French forum we have a discussion to compare two type of principle of building
    First one named (in French !!);) Strongall "flat"ticker plating and nothing behin
    or conventional buiding with plating less tick, frame and stiffener and little "curved" plating .:confused:
    I am not clear at all !!
    First example :
    plating 15 mm height of the plate 2000 mm and 1860 mm large, flat.
    Second example :
    plating 10 mm, height of the plate 2000 mm and 1860 mm large , with to frames of 110X12 section ( in the 2000 mm direction), stiffeners of 60X8 mm each 300 mm and a curve of 68 mm for the 2000mm height.
    I want to compare the difference of the 2 structure, for each flat part I could (may be :D) calculate that but I don't take all in "interaction" with the curvature ?
    If someone could help he will be welcomed;)
    Thanks
  2. TANSL
