RMA
Junior Member
- Joined
- Sep 3, 2019
- Messages
- 26
- Reaction score
- 16
- Location
- Old Saybrook, CT
Hello all,
I'm aware of similar threads on this forum but my project has very different engineering challenges so I'm starting a new thread.
I'd like to build a divinycell foam-cored fiberglass dinghy similar in design to the new OC Tenders made in New Zealand (which undoubtedly are fantastic boats, but would cost ~$8000 USD by the time they are shipped to NE USA).
Dimensions:
LOA- 8.8'
Beam- 5.1'
LWL- 8.6'
Draft- 0.75'
OC Tender claims the weight of their OC270 model (with similar dimensions above) at 77 lbs for the fiberglass version and 64 lbs for a carbon fiber version. I'm not an engineer but to achieve such weights from my calculations, there is no way they are using more than a single layer of reinforcement material on each side of the foam core. So I'm assuming a lot of the hull's rigidity comes from its many angles and the partial deck that acts to stiffen the upper part of the hull.
My goal is to replicate the lay-up as much as possible to achieve an ultralight dinghy that is still capable of daily use.
My guess is at these weights, there isn't CSM anywhere on the boat as this would add substantial weight without any real structural support. Biaxial, or triaxial (45/-45, 0) seem like the only material that could provide enough strength in multiple directions while still keeping the weight down.
So, given the intended use (daily tender while cruising), I'm wondering what the engineers (or those experienced with laminate schedules) think about such a design. Is it possible to emulate? I've attached a table with 3 different laminate options and the weight associated with each. I would be doing all of this by hand layup because vacuum bagging/infusion would make this a less cost-effective project than it's worth. I'm not so concerned matching the weight of a manufactured product but would still like to keep the dinghy as light as possible (maybe <90 lbs).
The table has formulas for everything so anyone is welcome to manipulate for their own uses. It assumes a wet layup cloth:resin ratio of 45:55 by weight.
Building a PVC foam core tender. Considering different cloth materials for the outer skins. All options would be a single layer of fiberglass on each side of the foam;
Option 1: 18 oz biax / 0.25" H80 divinycell / 18 oz biax ------- 80.56 lbs
Option 2: 36 oz quadraxial / 0.25" divinycell / 23.5 oz triaxial ------ 105.6 lbs
Option 3: 23.5 oz triaxial / 0.25" divinycell / 23.5 oz triaxial ------- 92.3 lbs
Your thoughts or recommendations?
Dimensions:
LOA- 8.8'
Beam- 5.1'
LWL- 8.6'
Draft- 0.75'
