I had a thought regarding rigging. I’m ordering a bunch of structural pultrusions shortly.
Had me thinking I may price out carbon fiber/epoxy mast pultrusions at the same time.
If I did this, I doubt they could do a pultrusion as complex as the attached pic without significant tooling cost.
So what if they just did me an oval and I added a track for batten cars on the outside of it?
1). Is that a good idea with a carbon fiber mast?
2). Is it advisable at all? Will it work or will they get jammed and stick or some other undesirable effect? We are talking large roach, flat top, full batten main.
3). How do I attach my tangs, spreaders, other hardware to a carbon fiber mast? Can I do this with fasteners somehow? Or am I stuck using epoxy, which I can’t use?
4). If I know the 2nd moment of inertia as well as an aluminum section that works for the rig, how can I specify a carbon section, given the material properties are different?
Moment of inertia only defines the shape of the mast. It does NOT define wall thickness. How do I know what wall thickness to use in carbon given I know which to use in Aluminum? The below wall thickness is for aluminum.
Thanks!
Thanks!
