thanks for the info blue knarr,
i was just going to roll the transom as i was doing before, i dont mind the stipple, as its not too bad with 1/4" nap roller, and easy enough to do light sand on top, but i have a ton of spider cracks and holes all over 3 sides of the center console, which will require lots of grinding, refilling areas with c.s.m. finishing etc. so with that much area and all the corners and angles on the center console, i feel like it would come out alot better with alot less sanding if i sprayed it.
and for sanding the transom, ive mostly been using a square palm sander with 80 and 120 grit paper, i just use long sweeps with light pressure, and make sure i change sanding direction all the time to prevent low spots. its come out very even sp far or i would have made a long block. i get the spray equipment this coming monday, so will do a small practice shoot on some outriggers i need to re-surface and see how it does and try to dial in adjustments before using on boat. the spider crack issue is going to be more challenging than i originally thought because the console layup on the sides is very thin and flexible, not much material there to begin with, i wouldnt be surprised if alot were all the way thru. if you guys have any ideas on how to build up these areas please let me know, i was just going to grind down past the cracks as ususal and then rebuild with c.s.m. gonna be labor intensive but dont know of any other proper way to do it. i also have my dash hole nice and sanded ready to glass my new insert in, but wanted to run all of my new wire harness and control cables thru from the stern while i have the big opening (way easier than crawling into console) i was going to peanut butter the sides then add 2 layers of 1708 to entire top of console to tie the insert into the surrounding area.
will post pics as i can. thanks everyone for your help. its very much appreciated.
