Fiberglass Wetout Chopper Gelcoat Resin Pump
Discussion in 'Fiberglass and Composite Boat Building' started by David2180, Jan 21, 2013.
  1. David2180
    David2180 New Member
    NEW LF-1 Pump System for Polyester Resin Gelcoat and Wetout/Chop. This little system won the award for "best new technology" in a European trade show in 2011. With the Phoenix 500 spray gun, and added chopper, this efficiently designed system can handle anything from a small hatch to a full size boat hull. It features a 15:1 Power Ratio with a 1" Pump Shaft. Output is 1.2GPM. Catalyst Ratios are adjustable from .75 to 3%. Fluid Sections are all stainless steel for durability. Its compact, efficient design and light weight (40 lbs) make it a system that you can move easily around your shop. Don't let the small size fool you. It is Powerful. This is an external mix system. Email me at david@tagmarinegroup.com, new never used paid 3200.00 will take $2500.00
    Id also be willing to trade a 25 to 35 hp four stroke outboard,newer model. front end loader tractor, or a side by side atv ,mule,gator,etc.
  1. aaronhl
  2. Jason Rodgers
  3. mrG
  4. Jason Rodgers
  5. Space
  6. Tom Peach
  7. DougDA
  8. abosely
  9. mudflap
  10. Jeeps
