reading with ears to hear
Vince, unless you get lines like- " WOW look at this guy- he's not on the right path.." and " WHY YOU @@##!"*%$, you call that a DEEESINE?" then its seems like its up to you to read the posts with more "hearing".
I'd suggest you read the post about the comparison to your work as "in the circles of those who do this for a living, my estimation is; you are at a very preliminary stage of development. In fact "we" don't even use that term "design" until there are many more settled decisions, the stage you are at is called in the industry a preliminary sketch, or perhaps a concept sketch."
That's how I read it, and I hope you could find "ears to hear".
I hope you'll continue to research small planing boats and learn to design one that both encompasses your visual aesthetics with a soundly designed hull for the waters you plan to cruise. In the mean time you might gain information more rapidly with a more "grasshopper" inclined (apprentice, learner, student-like) interpretation of the posts, and less idea that you're being impugned.
With that said, the chine in profile has no need to hook upward toward the sheer in the last foot or two of its run. This makes an 'unbuildable' shape, gains nothing for entry and is not considered 'fair', so that line's finish at the bow, in profile, could use your continued attention with an eye to refinement.
The chine(s) reverse for about a 1/3 of the hull and then become plumb aft amidships toward the transom. This has no function in a planing hull that I'm aware. I have seen hulls where the reverse chine is limited to the forward 1/3 of the hull but they were all metal and I think it will be a builder's problem in wood. It is generally accepted that if you reverse the chines (step outward in section horizontally) that you're doing so to reduce spray forward and to increase area and possibly vector the chine's wake release, aft.
The plumb chine plate aft would give more performance if it were between horizontal to 5 deg downward and in plan view, taper (as mentioned above by others) slightly aft amidships but not more than a few percentage of the overall width of the chine plate. In this case the inner is almost strictly parallel to the keel in plan view. One reason is that the warped shape is actually more drag than a constant V and if you add to that a tapering surface INSIDE the wake release point, at the outer chine, you will add MORE drag to that surface with this shape.
If the bottom is tapered more than 8 or 10 % in the run of a planing boat they 'squat' -or run with a bow high attitude (greater than 5deg pitch) because the loss of area is roughly equivalent to a rounded butt line, in profile view, of the same surface.
Some tapering of the outer chine in plan is very desirable as it gives a shorter turning radius to the hull since it will allow a greater roll into the turns; deeper roll than a completely parallel chined boat will.
Already mentioned is the aspect of deadrise at 1/3 aft, or the master section, as this is most often the section at the leading edge of the running waterline. Therefore the reason it has been mentioned above about the difficulty of designing a well found and reliably controlled warped bottom is because as speed increases on any planing surface (conventional bottoms) this line moves aft and therefore the warped bottom presents dozens -hundreds of different "bottom" configurations to the water. Designing for one of these bottom to waterline instances is "a full day's work for a grown man" as they say of labor tasks in the building trades. I will echo the advise above about close attention to this aspect of your design, and recommend that you research and document as many other boats as possible for references about the forward and aft deadrise angles in your warped bottom.
This point is where you will acutally 'take' the water at speed in a chop, so this where the "ride" comes from. If it is less than 18 or 20 degrees, at this point, and your boat is less than a 1500lb. all up wt, you will "beat your eyes out" in a small short 2' chop (less than 30 peak to peak for your 20'er) at 25 mph. Fact. You can ease the ride by increasing wt, up to a point or you can sharpen a 10 or 12 degree bottom or slow down. I believe once you've gone around this item in the design cycle a few times you'll 'see' more of what
So, I hope you can hear more than one person saying (with repect and consideration for your enthusiasm) "from our experience"; you are embarking on a challenging design project since the warped bottom is more complex than the monohedron or constant deadrise hulls to design well. There are elements of these hulls which have caused some problems in the past and you may care to watch these areas as they arise in your project.
If you haven't already, may I suggest that you subscribe to, or acquire back issues of, the Classic Boat
ING Magazine (underline to emphasize the name), they're at
classicboating@webtv.net phone (262) 567-4800 in Oconomowoc WI. They are exclusively involved the mahogony runabouts you've taken as inspriation.
wishing you fair lines, a sweet sheer and an interesting building project, leading to a beautiful, strong and reliable boat.
Cheers,
kmorin
