explanation for the next steps in other words (dipole)
Discussion in 'Hydrodynamics and Aerodynamics' started by gerar, Mar 6, 2013.
  1. gerar
    gerar Junior Member
    I am trying to understand the lamb-chaplygin dipole solution.
    can someone explain me the green lines in other words please?
    this is the proof:
    When introducing the stream function, the steps that you usually take are as follows:
    1) replace u and v by the stream function.
    2) Derive the horizontal momentum equation (for u) with respect to y and the other with respect to x.
    3) Eliminate the pressure term, to end up with a single equation in ψ.
    so:
    v = -∂ψ/∂x, u = ∂ψ/∂y
    (∂^2)ψ/∂x^2 + (∂^2)ψ/∂y^2 = f(ψ)
    if we put f(ψ) = -(k^2)*ψ. where k is a constant, and transform to polar coordinates r, θ, we get:
    (d^2)ψ/ dr^2 + (1/r) * (dψ/dr) + (1/r^2) * (d^2)ψ/ dθ^2 + (k^2)*ψ = 0
    which is satisfied by:
    where Js is a bassel's function.
    any help appreciated! thanks!
  2. Submarine Tom
    Submarine Tom Previous Member
    I would have thought baeckmo to be all over this...
  3. gerar
    gerar Junior Member
    Hi Tom, what do you mean? I didn't understand.. sorry :/
  4. Submarine Tom
    Baeckmo is a member on this forum, he usually has a lot to say on matters such as these.
    I'm surprised he hasn't spoken up.
    You could try sending him a personal message.
  5. gerar
    gerar Junior Member
    ok, I will send him a message.. thank you very much!
  6. jehardiman
    Likes: 1,354, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    What you are looking at is called a mathematical contrivance. I hope you have had a course in the solution of differential equations or this is going to get messy
    What we need to do is find a finction (f) of ψ so that when we evaluate it, a solution of the stream function can be found. When we have a dipole, the stream function is a function of location of the point we evaluate, either x,y from the dipole, or the distance (r) and angle (theta) to the pair. What the proof did was to first convert the axis from a Cartesian coordinate system to a polar one. Notice that the (∂^2)ψ/∂x^2 + (∂^2)ψ/∂y^2 = f(ψ) term can be separated similar to the x^2+y^2 = r^2 of the rectangular to polar conversion. If we set r^2 = f(ψ) then all we need is a f such that it is easy to extract an r and theta...i.e. -(k^2)ψ (notice that when we take the square root of this we will end up with a complex conjugate necessary for a polar solution and also that v = -∂ψ/∂x, u = ∂ψ/∂ satisfies the Cauchy-Riemann conditions). Now we do the substitution and differential gradient (▼ couldn't find a font with the grad symbol) to get a form of the Bessel equation (x^2*y''+x*y'+(x^2-n^2)y=0) where the Bessel’s Function (a polar version of Jn(x)) is a solution.
    Or at least that's how i remember it.
  7. gerar
    gerar Junior Member
    wow, thank you very much! you helped me a lot.. I think I start understanding it! thank you!! you explained very clear!
  8. Submarine Tom
    John,
    You never cease to surprise me!
  9. jehardiman
    The solution methods of linear and non-linear differential equations is part and parcel of a modern engineering (Naval Arctitecture) degree. When I was in school we had to do this kind of stuff (dipole flow solution) by hand, even stuff like work out multiple dipole couplets to give a near net hull shape. It always helps to know the underlying math when evaluating computer progam output.
    FWIW, it is always better to understand the math because mathematics is the language of engineering, science, architecture, art, and as Einstien asserted, God. Even da Vinci, 500 years ago, had the following statements that I keep up on my office wall:
    and
    So I won't give Heinlein's Lazarus Long quote I also keep up on the wall ;).
  10. Submarine Tom
  11. gerar
    gerar Junior Member
    hahah Amen!!! :]] and thank you again!
