European rules for a small boat builder...
Discussion in 'Boat Design' started by Grant Nelson, Jun 28, 2011.
  1. Grant Nelson
    Likes: 12, Points: 0, Legacy Rep: 163
    Grant Nelson Senior Member
    Hi,
    I am designing small boats, say 3 or more meters. I also want to build a few for clients. I have tried to understand what I might have to do in regard to ISO and CE rules and regulations, but it looks like a ton of work and costs. There are a lot of small boat builders in Europe I would guess. How do they do this? Any concrete instructions, etc. would be much appreciated!!!
    Grant
  2. Alik
    Likes: 376, Points: 93, Legacy Rep: 1306
    Alik Senior Member
    Grant, for such small boats certification is simple and can be done by testing. One needs to arrange Owner's Manual, GA drawings; check-lists will be filled by inspector. Stability and flotation tests would be required; scantlings are not required.
    Actually there are few options. The procedures are presented in RSG guidelines.
  3. daiquiri
    http://www.rsg.be/
    Requires a free registration before consulting and downloading the documentation.
  4. gonzo
    Likes: 2,053, Points: 123, Legacy Rep: 2031
    The CE certification is pretty straightforward. There are several options given for testing or meeting standards. You can also provide alternate means of meeting standards.
  5. Grant Nelson
    Thanks all, there are a ton of documents there...and versions... any pointers to the key ones I should look at. Also I see that I still would need to go to a local CE certification authority... any idea how much they would charge for a one off boat, built for sale?
  6. TeddyDiver
    Likes: 141, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    Smallish vessels like you intended can be "self certified" by the manufacturer..
