PART 1:
I have a pretty strong epoxy allergy. Enough to break out in hives and have problems breathing from just the smell of epoxy. I'm allergic to the amines in the hardener. BPA is terrible for you, but not something I'm allergic to.
Does anyone know of a hypoallergenic epoxy without amines in the hardener?
PART 2:
Assuming I can't find any epoxy to use, I still need to complete the interior of a fairly good size boat. It's a completely empty hull. It's balsa core and foam core in various parts, with a 34oz fiberglass skin (epoxy) over the core.
What are some alternate ways to finish out the hull? I need to place runners (like stringers, really) along the hull to support cabin soles, to support ceilings, to act as frames for cabinetry, etc. A normal person would epoxy these into place. I can't do that. Is it possible to use screws into the laminate or is this asking for trouble?
Since I can't use foam and epoxy for the interior, I figured I'd use 1/4" marine ply, glued and screwed then painted with epoxy for most things, stick frame. What else can I do?
I will hire someone else to get into the epoxy and paint all of this wood with epoxy to waterproof it.
For things like stairs to go down into the hulls, I already have laminates left from hull construction. I'm wondering if infusing them and having someone else mix the epoxy outside the boat and piping it in might work?
Any good ideas here?
PART 2:
