CDK
retired engineer
- Joined
- Aug 4, 2007
- Messages
- 3,324
- Reaction score
- 149
- Location
- Adriatic sea
The boat is going to stay in the water this winter, so once every few weeks I start the engines and let them run until the temp gauges are in the green.
Last time I noticed the starboard engine temperature approaching the red zone. I lifted the floor panels to check the coolant level, but instead of greenish liquid there was only pitch black oil...
These VW 1.9TD engines have an oil cooler sandwiched to the oil filter and are prime suspects, so I installed a new one although there seemed to be nothing wrong. I also flushed the cooling system, started the engine and noticed again a high temp and more oil surfacing. After switching off there was the typical sound of boiling water and some splashing from the coolant tank.
Subsequently I removed the pump assembly, which is a very difficult job because it is located at the lower part of the engine, almost hidden by the alternator. But both the pump and the thermostat seem OK, although there was a lot of hard sediment I have no explanation for.
The oil/water contamination can only come from a blown head gasket, but what may cause the high engine temperature? The engine never caused any problem since it was installed nearly 5 years ago and never did more than 3000 rpm.
