Currently I don't have genset auto-off function if battery changed to 90%. It will charge further and overcharge if I don't do a manual shut off a genset, as open-circuit voltage greater than battery full-charge voltage. Auto-off problem I have to solve - will add some voltage comparison relay, it will disconnect spark plug supply, when voltage will be 90% of full charged battery. This relay will be cheap.
I know my ICE engine have 3000-3600 RPM, according to specs. I bought a BLDC generator, that provide 80V open-circuit at max RPM (3600). Under load, voltage will drop, but it still higher than battery full-charge voltage and charge work. I made a test with wattmeter at reserve 48V 75Ah battery, but my main battery is 36V 180 Ah. Test with main battery I will do later.
Generator is connected 1:1 directly to ICE shaft, no belt or gear. No water cooling, except wet exhaust. I adding a water to exhaust tube using 12 V pump to reduce noise and temperature of exhaust gases. Engine body have air cooling system, that why I wrote it need an air access with cooler. As you can see at picture above, my genset installed under the cockpit. This is reduce noise and made genset independent of rainy weather. Air is injected to genset compartment by the cooler and there is a passage outside of compartment for hot air.
"Cheap" engines with water-cooled body have a price 2-3 times greater than with air-cooled body. Currently I'm not interested in high price engine, maybe I will change my mind in future, but not now.
Use genset to warm a cabin I think it is a bad idea. It work not all the time, it work just to charge battery when you at long passage (case when no wind and you need long motoring), so you can warm up cabin a limited time only, this is not convenient. If you will run it several hours in a row, when battery fully charged, you will burn a lot of fuel just to warm up cabin.
More optimal way to use air heaters as used at heavy trucks, like "eberspacher airtronic". It provide a 2 kW of heat just for 0.28 l of fuel per hour.
Cheap ICE engines are not designed to have a lot of workhours until replacement, this is another reason to do not use them as heaters only,
