Hey everyone! I'm new here, but I am working on a design project and have a few questions, mostly surrounding structure. I have done quite a bit of design work, but I'm not as familiar with composite work on small boats.
Project background: My project is a 12 m trimaran (LOA == LWL), with a vaka/center hull that's about 2.2 m BWL, and amas/side hulls are about 0.6 m BWL with an overall beam of 10 m. My goal is ultimately to be an oceangoing-capable vessel and meeting all the appropriate ISO requirements for the same.
I'm doing the initial weight estimate, and I'm trying to figure out an appropriate structure. I have a few questions: (1) Effectiveness of sandwich panels. (2) Initial structural layup. (3) Necessity of longitudinal structure. (4) Aca/cross structure loads. (5) Ancillary structure. (6) Other thoughts.
1) For the vaka, I would like to do 75 mm/3" of PVC (H80 or similar) foam not only for structure, but also for insulation and flotation. When I studied composites back in the day, the core of a sandwich panel was simply the "web" with fairly limited structural effectiveness, but also no limit as far as as thickness. However, Larsson & Eliasson make a comment when discussing sandwich panel cores which suggests that there is a limit to their thickness due to a need to transfer the load between the inner and outer lamina. Is there a good rule of thumb for this? Is 3" too much? What about semi-hollow 4"? (For the weather deck, I'm running longitudinal conduit for both running rigging and distributed systems in the main deck/cabin overhead.)
2) The immersed vaka bottom structure is a stiffened panel design with (currently) both longitudinal and transverse beams, as well as 8 full height bulkheads (3 WT/FT). As mentioned, the vaka has 75 mm H80, and, based on the "Multihull Structure Thoughts" post on this forum, it seemed reasonable to assume a single layer of 1708 on each side of the core. (Assumptions: 50% wetout with PVE versus manufacturer recommended 50% by weight. Manufacturer recommended paint/coatings. 12.5% weight margin for all weight due to uncertainty.) How unreasonable is that? For the amas, I went down to 18 mm foam on the sides and deck with 1708, retaining ~75 mm foam only on the bottom (from the baseline up to the waterline). Is that too light? In addition to transverse bulkheads, there is a full length deck about mid-way up.
3) Looking at most production 7-15 m boats I've seen, there isn't much in the way of longitudinal structure. I understand that under about 50 m boats typically experience seaway loading as a global load, and so the shell structure is typically sufficient. I currently have a pretty decent amount of weight budgeted for 7 x 100 mm wide floor beams (1708 top/sides, H80 core - it would probably be more effective to use uniaxial glass rather than 1708 for that). How excessive is that? Just use one or two centerline floors to distribute the mast loading? just use localized beams under the mast?
4) For the larger ships I typically work on, we use class-based seaway loading for transverse loading of the acas. (We also use seaway loading for longitudinal strength, but that's another conversation.) However, much of the transverse strength calculations for sailboats are based on righting moment (e.g. rig strength). I currently have a way overstrength cross structure (a total of 10 carbon fibre beams with 2 m of vertical separation between the top 4 and the bottom 6 - one of the beams, on its own, could take the full force at beyond the maximum righting moment of the craft). Is there a better way to calculate transverse loading?
5) For ancillary structure (e.g. outfitting, non-structural weather-exposed panels, the coach roof, etc.), how light can I reasonably go? For surfaces that will have people on them (e.g. benches, the decks in the amas), I currently have 18 mm of H80 foam with either 1708 (the decks) or wood veneer (the benches). Is that too light? For the vertical surfaces, could I go down to H20 with 6 oz boat cloth (or veneer)? For the coach roof, I currently have 75 mm thick H20 with 6 oz boat cloth. Is that too light to resist a crashing wave, or just a human handling sails? (While the coach roof is over 4 m AWL, I have certainly been in situations where I've gotten wet much higher up.) What about near-vertical forward facing structure? Is that too light?
6) What else should I probably be thinking of?
Thanks,
- R/TDG
Thanks,
- R/TDG
