I am surveying a Dufour GL350 and noted some extra glass laminate on top of the hull liner in the bilges. It looks reasonably well-executed, professionally done. The keel bolt nuts and backing plates where removed for the glass work, then re-installed. The reinforcement is under the forward and aft keel bolt backing plates. The center forward set of keel bolts are just through the smooth liner, as expected.
Has anyone seen this extra fiberglass from the factory? If not a factory mod, then my concern is that the boat suffered some grounding damage and the extra glass was to cover cracks and or laminate damage. I will be hauling her out next week to inspect the keel join and laminate from below.
Thanks for any first hand knowledge of this model.
