Dual helm stations, dual control heads for dual engines
Discussion in 'Diesel Engines' started by Scrumble, Feb 2, 2010.
  1. Scrumble
    Likes: 3, Points: 0, Legacy Rep: 75
    Scrumble Oram 46'C MS Builder
    I am building a motor/sailing cat, with inboard diesels. The helm locations are at 11m and 4.5m from each engine and the engines are greater than 6m apart (all by cable route).
    I wish to have one dual lever control head at each helm and have not dealt with bowden controls in a dual station system before.
    My searches for information about how the different brand types of exchangers/transfers/dual station units work in a system has only come up with high level schematics.
    I suppose drawings will be available once I purchase a unit or four but this may mean a choice not suitable for the spaces I have available.
    I would greatly appreciate some information or direction to a net source I have not been able to find.
  2. powerabout
    powerabout Senior Member
    go electric
    (cable systems are disappearing)
    or Morse Twin SR would be the most common dual entry duel control in the world if you want 4 levers ( never give problems)
    Single lever dual station are problematic as you need a slave box to disconnect the other station automatically..always gives problems and can cause you to loose control of gear and throttle.
    http://www.teleflexmarine.com/library/instructionmanuals/SR Twin Control Manual.pdf
  3. Scrumble
    Thank you, powerabout for the link, its an excellent start.
