Drive shaft for remote v installation, please advice
Ok, maybe I misunderstood something so please correct me. . . . . .
I'm sorry, on second thoughts you were right in post #6, that is if the torsional damping shaft with it's the CV couplings solves the angle difference with the prefered prop shaft angle as result, so you only need the lower green unit in the picture if the target is to big to solve the desired angle difference with the upper set of CVs alone.
But take note, where you don't apply CVs, you need a perfect alignment in all directions, otherwise this will give vibrations in the boat, and much extra wear on the not perfectly aligned parts.
That's what I understood. He inclines the transmission to get a different angle on the propshaft, and the resulting angle between motor and transmission can not be solved by a pair of universal joints so he needs another form of CV joint. Now with the new angle proposed he must check again and see wich solution to take:
1. Incline the motor to be inline with the transmission.
2. Use a pair of universal joints.
3. Use some form of true CV joint.
The only difference to the initial situation is that the driveshaft between motor and transmission is now shorter.
Design Guidelines for Drive Shaft Installation Angle | Engineers Edge https://www.engineersedge.com/vehicle_driveline_design.htm
this might help plus there are a bunch of sites on driveshaft design
There will not be any need to have a thrust bearing between the engine and transmission. Only between the v-drive and the prop shaft but
all Vdrives have this as an inherent part of the design as the out put shaft is meant to be hooked to a prop
The problem that you will have though is that the drive shaft between the vdrive and engine will need the ability to slide to compensate for the
slight movement of the drive shaft as the u joint rotates. Plus even more importantly, you will not be able to mate up the flanges on the drive shaft
to the flanges on the engine/vdrive within thousandths of an inch. So that you will build in a tension element into the shaft. Obviously not compression or you would not be able
to put the shaft in. With the flex of the boat, you would be imparting high loads to the engine/vdrive flanges.
I think that some of the marine couplers can accommodate some small length changes
