Drinking water from sunlight
Discussion in 'All Things Boats & Boating' started by Fanie, Feb 4, 2013.
  1. Fanie
    Fanie Fanie
    I thought this is super cool, a way to make drinking water even from salt water.
    Solar Potable Water Generation
    http://www.watercone.com/product.html
    It's based on the libich ? (help with the correct spelling) cooler we learned of in school in grade 1 where water is heated then condensates and you get clean water.
    I'm sure if one add a shiny reflector to shine more sunlight on the cone it will also generate more water.
    So now that you know you can never again be caught adrift somewhere and complain you are thirsty...
  2. hoytedow
    Interesting.
  3. PAR
    You'd die of dehydration, before it made enough water to save your butt. Surface area is the key to that sort of thing.
  4. hoytedow
  5. Stumble
    Stumble Senior Member
    The recommend fluid intake is 3 liters a day, the cones produce ~1l/day. Seems like making them larger would have been the way to go.
  6. bntii
    bntii Senior Member
    One of my engineering courses had us make up a solar still.
    Fun project & we tossed around the army surplus 'beach ball' design and also learned that T. Edison was a big fan of desalinators & tried to design one to condense fog for dorymen lost at sea in the Grand Banks fishery.
    Edit- I unsucessfully looked about for a reference to the Edison invention, but stumbled on this:
    http://www.rexresearch.com/airwells/airwells.htm
    Interesting bits
  7. armando12
    Likes: 6, Points: 0, Legacy Rep: 120
    armando12 BalckRock
    Edit: sorry my mistake
    for some reason i cannot edit this
    edit2: oh it worked, but now is all gone
  8. hoytedow
    http://inventors.about.com/library/inventors/bledisonpatents.htm contains the allegedly complete list of Edison patents, which contains many for electroplating, electrolysis, storage batteries and their elements, but I could not find on first try any patents for desalination apparati.
  9. hoytedow
    I feel your pain.
  10. troy2000
    troy2000 Senior Member
    Does anyone here really drink 3 liters of water a day? I certainly don't; I'd spend my days running to the bathroom like a pregnant housewife.:)
    That recommendation, commonly rephrased as, 'drink eight (8 oz) glasses of water a day,' is actually based on a person's total water intake -- including that contained in your food.
  11. daiquiri
    LOL, this was funny! :D
  12. Number4
    Number4 Previous Member
    I see the watercone is selling for $60!
    It is not such a revolutionary idea, just simple distillation.
    You can make one with two bowls and a plastic bag.
    Put a weight in a little bowl and put it inside a big bowl of salt water (or pee). Tie a plastic bag over the top, put a weight in the middle of the bag. The water will evaporate then condense on the bag and drip into the little bowl.
    You could use two plastic bottles and a piece of hose.
    Going one step further, build a sealed box with an angled glass/plastic top. Run a gutter along the inside of the lower edge. Attach a hose to the end of the gutter and fill your water bottle.
  13. rwatson
    rwatson Senior Member
  14. daiquiri
    Perhaps it would be a good idea to add a spell check to the process of ISO certification. :rolleyes:
  15. troy2000
    I looked that one up, and it supposedly only produces from half a liter to a liter of pure water a day. That isn't very much capacity for the money.... especially if you need water for more than one person.
    1. sdowney717
    2. Clam Island Shipwrights
    3. cluttonfred
    4. Squidly-Diddly
    5. rael dobkins
    6. Squidly-Diddly
    7. Fanie
    8. togoodwin
    9. Fanie
    10. sdowney717
