Yes, that fitting cannot be removed, I tried. The polyurethane is an excellent adhesive. I also can not remove the hose from the fitting, I really tried hard.
The polyurethane is gluing hose into fitting and fitting into hull.
I did really try hard because I decided to add a second one like this right next to it, so I now have two Rule 3700 'crash' pumps for backup to the Rule 2000 main pump which does have your standard thick walled hose. I ended up having to cut the hose and use a screwdriver to pry the pool hose out of the fitting.
Granted the hose is thin wall suction hose, but this is low pressure it wont bother that hose.
The inside of the hose is smooth. This hose is quite flexible.
If you know swimming pools then you are familiar with this hose.
I like to use stuff I already have on hand to save money, otherwise I would have bought some more standard hose. You could step on this hose and squash it, but that is not too likely they way my bilge is set up and the way the hoses run.
I will put some grey electrical conduit clamps on the hose to secure it so it wont move around.
This hose is stronger - tougher than the real cheap plastic bilge hoses they sell for bilge pumps.
I mean if this crappy hose is ok for bilge pumps, then this pool hose is all the better for bilge hose.
http://www.jamestowndistributors.co...o?pid=12911&familyName=Shields+Bilgeflex+Hose
