Hey everyone,
I have been rebuilding a bayliner 2155 ciera sunbridge.
As part of my rebuild process I have been trying to loose weiggw where I can by using light weight materials and omitting things I don't need such as a windscreen wiper and motor. My reason for this is it has a 120hp engine and I reckon it will need all the help it can get to push the boat onto the plane.
The jobs going well but of course as a first timer it has been hard work fibre glassing etc.
Obviously the transom was rotten, however the stringers were only bad for about 3". So I have replaced the transom (took 2 attempts to get the glass right) and the short stringer sections.
Also the engine stringers were rotten and the rear cross member timber that my engine sits on. The long engine stringers seat the bigger V6 and the cross member seats mine.
Can I omitt these engine stringers and just install the cross member timber as that's all my mount needs.
Also when I removed the 3" section of stringers I also cut away the boxing that sat on it, do I need to replace this. I am hoping to leave it off as it gives me a view of what's going off in hidden cavities.
Any help and advice in this will be greatly appreciated.
On the photo you can see my new transom after a removed my first attempt of fibre glassing, just to the left you can see where I have removed the small rotten section of stringer and boxing and the big dark thick lines in the V are where the rotten engine stringers sat.
