Diamand stays and planning of the main
Discussion in 'Sailboats' started by Bertil, Mar 21, 2020.
  1. Bertil
    Likes: 1, Points: 8, Legacy Rep: 25
    Bertil Junior Member
    I have diamand stays with three spreaders. 1 pointing forward and two pointing backwards appr 10 degrees. Hard tighed.
    My question:
    -If you have an afterstay and likes to plan the main is it possible to do that with diamond stays holding back. Then you can instead have a mastheadrig instead of the fractional rig as I have today Is that true?
    I have an old trimaran weighing appr 1100 kg and total length 8,5 m.
    Could you help me decide.
    Likes: 2,096, Points: 123, Legacy Rep: 2031
    Are you trying to eliminate the back stay?
  3. Bertil
    Yes! The backstayS,
  4. gonzo
    That would require an engineering analysis of the rig and hull structure.
