Deck below waterline
I am wondering if this is in fact applicable.
Your statement "retention level larger than Volume/40 , ENTIRELY contained within the LH/2 of the BOW shall be either quick draining or drain to the bilge.
I would interpret this as if you have a recessed volume completely separate from any other part of the boat in the front half of the boat , Ie "contained within the LH/2 of the bow" that it has to be drained overboard or to the bilge.
Perhaps a boat that might have a separate seating area, open bow rider or any other "entirely contained recess" within the front half of the boat might be where this standard applies
Maybe they are just trying to ensure if you take 1,000 pounds of water over the front of the boat into a separate recess, that you can get rid of it through drains or into the bilge where it can get pumped out
Attached is some explanation for 12217 note that they are on version 2015
https://mycourses.aalto.fi/pluginfile.php/189945/mod_resource/content/1/2.2 Stability.pdf\
Note also on page 11 that option 6 refers to inboard installation only but your profile shows that it is an outboard
It also appears that there are three ways to make a boat compliant, flotation, high freeboard midship and bow, (are you not compliant in this regard?) or a partially decked hull.
I think that if you are investing the money or have invested the money to build moulds etc for this boat you need a clarification of the requirements. Rather than rely on your interpretation or mine
My take, and you will see a comment further in the paper about location of self contained recesses, is they are trying to deal with closed recesses in the front half of the boat that need to be either self draining or drained to bilge. As per your quote in your initial thread "entirely contained within LH/2 of the bow shall either be quick-draining (overboard) or drain to the bilge"
If you could forward the ISO document it might help in the discussion. I could not find the entire 2015 document available without buying it
